Possibly good lightweight rotors
Driving is the next best thing
http://www.racingbrake.com/NISSAN_MAXIMA_s/259.htm
Unfortunately they don't have blank rotors but the price and specs (weight) seem to be pretty good.
their 6th gen front rotor: 17lbs, $109
their 5th gen front rotor: 14.2 lbs, $92
In other words they weigh almost as little as two piece rotors and cost 1/3 of their price.
Discuss...
Discuss...
I'm pretty sure that 5th gen rotors are 16lbs each and 6th gen are 21lbs each.
Edit: yap, that's correct: http://doug.maxima.org/showpost.php?...14&postcount=1
Originally Posted by michaelnyden
I can't, my rotors are 2 piece and slotted 6th gen's...and are maybe one pound lighter...that's with a T6 6061 hat...think about that...
I'd be scurred of a rotor with walls that thin in a performance application. The onyl place you can save appreciable weight on a rotor is by making the walls of the disc thinner, which decreases heat capacity and lowers overall braking effectiveness over the long haul.
Stock 6 gen rotor is 21lb, so they're knocking 4lb of "good" out of the rotors.
you can go much lighter on a 2-pc rotor due to the better materials and aluminum hat. I doubt a cast iron rotor uses the same stuff.
Just recently I've been getting my car back to where I want it. Ordered a whole boatload of shat... including brakes. I forgot about your 2pc option, cripes ...
Well these are in my garage now, so .. heck ... I don't Autox, so hopefully I wont die in my typical daily drive/semi every now & then hardstop.
RETURN UM lol get the 2peice, and while you're at it; buy me some too
Cant_Get_Ryte
08-28-2015 06:41 AM
RealityCheck
08-05-2015 06:18 AM
