Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
THE BBK PiCTURE THREAD (Show off your BBK setup here)
Old 10-02-2007, 12:34 PM
  #161
Brembo Gran Turismo BBK utilizing 13" two-piece rotors. 12.65 lb just like Black birdVQ said.
The Wizard is offline
Old 10-02-2007, 12:36 PM
  #162
More...
Old 10-02-2007, 01:50 PM
  #163
ThurzNite's Avatar
Are those rotors drilled by Brembo too? That's the most holes I've seen on a Maxima.
Jae
ThurzNite is offline
Old 10-02-2007, 02:00 PM
  #164
Jae
Well, yes and no. The holes aren't drilled after the rotor is produced, they are part of the mold Brembo uses and cured in place.
Old 10-02-2007, 05:14 PM
  #165
ThurzNite's Avatar
does drill = mold?
Jae
Old 10-02-2007, 06:00 PM
  #166
Curb Rash Repair 100 a wheel
Maxima112's Avatar
does drill = mold?
Jae
mold? i dont think mold could survive in that kinda temp, one brake would burn anything close to that...
Maxima112 is offline
Old 10-02-2007, 08:29 PM
  #167
retired moderator
irish44j's Avatar
which is the ONLY acceptable way to do it.
Drilling a blank just weakens the structure. Casting it with the holes does not.
irish44j is offline
Old 10-03-2007, 12:05 AM
  #168
ThurzNite's Avatar
i'm confused what "cross drilled" refers to. Why does brembo's website say the holes are drilled? Are they drilled or casted?
Jae
Old 10-03-2007, 12:33 AM
  #169
MorpheusZero's Avatar
Jae
They're cast, but "cross drilled" sounds cooler than "cast with holes in them."
MorpheusZero is offline
Old 10-07-2007, 05:39 PM
  #170
the max thats growing up
chinolatino215's Avatar
Cool
i have a 4th gen maxima im thinking about doing a bbk with the works and all...W hat would be the best way to go as far as choosing the company thats sells the kits...I know that Brembro does not make them for the 4th gen anymore.... What can i do i really wanted them but hey thats life....What to do fellas can some one help me out
thx
chinolatino215 is offline
Old 10-07-2007, 07:32 PM
  #171
retired moderator
irish44j's Avatar
Jae
Actually, IIRC Brembo doesn't cast any of its 1-piece rotors with holes - only the 2-piece (more expensive) rotors.
When you buy standard Brembo rotors with holes, they have been DRILLED after the fact, not cast that way.
irish44j is offline
Old 10-07-2007, 08:01 PM
  #172
drag racing is for wussies
BlackBIRDVQ's Avatar
Hey Wizard,
How do you like the kit ? I just had my 1st track event with them and I think I will dump the Brembo pads for some Hawks. The floating rotor design takes getting used to when braking on the track, initially it feels like the rotors are warped under light braking when the brakes are HOT... but when you hit them harder they just stop the car like crazy.
I would also like to thank you for posting pictures of 17" wheels over them. I am going to pick up some 17" track wheels so I can run my Hoosiers on them, and I wasn't sure if they where going to clear the calipers.
I need to upgrade the rear brakes now, they actually get really hot on the track and stink a bit. HPS on stock rotors.
BlackBIRDVQ is offline
Old 10-27-2007, 12:22 AM
  #173
i30krab's Avatar
http://
i30krab is offline
Old 11-04-2007, 10:05 AM
  #174
MAXSE2kMT's Avatar
been waiting a long time to get this done right; blehmco bracket, 13" baer rotors, 300zx calipers under 17" ssr's.
MAXSE2kMT is offline
Old 12-12-2007, 06:52 AM
  #175
Corelventura's Avatar
MAXSE2KMT, can you pm me the price for the 13" baer rotor and where do you get it from? I am looking for a set also, thanks.
Corelventura is offline
Old 12-12-2007, 09:21 AM
  #176
A33 VQ30DEK's Avatar
if you're using the 13 inch rotors those wouldn't be the blehmco bracket.. they would be the jeff92se brackets
A33 VQ30DEK is offline
Old 12-22-2007, 07:22 PM
  #177
L.M.L.
got an idea here..
Old 12-31-2007, 08:48 PM
  #178
2nd Gen Boostinator
Big_E-Dog's Avatar
i guess i can add as well
87 maxima se
q45 dual piston calipers
q45 cross drille drotors
vg30et motor
Big_E-Dog is offline
Old 02-29-2008, 04:12 PM
  #179
Afterlife's Avatar
Well got mine put on now...got bored at work 1 day :P
300-Z Calipers/rotors milled 4mm in diameter everything else stock for now no mods had to be done to get them to fit everything bolted right up,hopefully have stainless lines soon!
Last edited by Afterlife; 02-29-2008 at 04:50 PM. Reason: 4mm spacers for the murano wheels to fit also.
Afterlife is offline
Old 02-29-2008, 07:40 PM
  #180
NiZMo1o1's Avatar
My A33 ( de-modded)
A34 Current
I upgrade z33 Rear Calipers on the A34
NiZMo1o1 is offline
Old 02-29-2008, 07:49 PM
  #181
retired moderator
irish44j's Avatar
don't recall if I ever posted pics...
Wilwood superlites + Blehm/coleman 2pc rotors (under my winter wheels in this pic)
irish44j is offline
Old 03-19-2008, 06:23 PM
  #182
Future Camaro SS owner
MyownNismo's Avatar
My new setup Stillen/PBR setup, Custom Coleman racing 2pc rotors.
without tires
with winter wheels
with summer wheels
MyownNismo is offline
Old 03-19-2008, 06:41 PM
  #183
I'm selling my Brembo kit if anyone is interested.....
Old 03-26-2008, 12:04 AM
  #184
GAMERA30's Avatar
Location: Long Beach, CA is where i live. Queens NYC is always home.
[IMG][IMG]<a href="http://s292.photobucket.com/albums/mm14/GAMERA30/?action=view&current=caliperclearance.jpg" target="_blank"><img src="http://i292.photobucket.com/albums/mm14/GAMERA30/caliperclearance.jpg" border="0" alt="Photobucket"></a>[/IMG][/IMG]
GAMERA30 is offline
Old 03-26-2008, 12:11 AM
  #185
GAMERA30's Avatar
damn ....messed up the upload
GAMERA30 is offline
Old 03-26-2008, 03:17 AM
  #186
NewfoundlandDud's Avatar
I got you covered.
NewfoundlandDud is offline
Old 03-26-2008, 08:49 AM
  #187
GAMERA30's Avatar
Thanks for the backup Newfound...here`s what I actually wanted to post.
92 Max SE ... cobra rotors,Q45 calipers,Maxxim Oxygene rims... Close fit huh ?
IMG]http://i292.photobucket.com/albums/mm14/GAMERA30/Cobrafront.jpg[/IMG]
GAMERA30 is offline
Old 03-26-2008, 08:50 AM
  #188
GAMERA30's Avatar
aww man ..... did it again !?!?!... anyone know how I can post a pic from photobucket ? ..=\
GAMERA30 is offline
Old 03-26-2008, 08:54 AM
  #189
Puppetmaster's Avatar
You missed a bracket before "IMG] is all:
Puppetmaster is offline
Old 03-26-2008, 09:32 AM
  #190
RacerX1320's Avatar
Is the Brembo kit the lightest rotor and caliper set up? Mike Jez Brembo kit came in at 37 pounds. Anyone have the total weights of their set up?
RacerX1320 is offline
Old 03-26-2008, 10:03 AM
  #191
GAMERA30's Avatar
thanks for the help puppet
GAMERA30 is offline
Old 03-26-2008, 10:09 AM
  #192
GAMERA30's Avatar
my z31 rears.
GAMERA30 is offline
Old 04-20-2008, 06:48 PM
  #193
mforrest100's Avatar
Although not a maxima, I thought it would be appreciated:
Too bad this setup isn't available for a maxima. I know I would have bought one for mine if I still had it.
mforrest100 is offline
Old 04-20-2008, 10:52 PM
  #194
96i30azn's Avatar
Damn, this thread is **** to me.
96i30azn is offline
Old 04-23-2008, 11:32 AM
  #195
Wild for Width
Fr33way™'s Avatar
Maxima or Z32 torque members (caliper bracket)?
Fr33way™ is offline
Old 05-30-2008, 02:49 PM
  #196
i SeE what you did therE
redmaxpa007's Avatar
300z bbk on an altima
redmaxpa007 is offline
Old 05-30-2008, 03:05 PM
  #197
Project Ruby......
4DRSpeed's Avatar
very clean on the altima. I just bolted up some G35 Coupe wheels. Feels great to have tons of clearance between the inner barrel of the wheel and caliper now compared to the crappy 17s I had.
4DRSpeed is offline
Old 07-08-2008, 10:42 AM
  #198
I'm needing a caw
Jeff92se's Avatar
Nice. What parts are used on that?
Jeff92se is offline
Old 07-08-2008, 01:18 PM
  #199
matt's stuff..
SE-R brakes are the same as an +04 maxima... so the rotors are stock..
Old 07-08-2008, 06:11 PM
  #200
GAMERA30's Avatar
HEY GUYS ?!?!?!.... I made a nice discovery for those w/ 3/4th gen maxima`s who want brembos. Using SER Spec V Brembos will bolt up. All u have to do is drill the rotors to 5 lug and they bolt right up. For a mock up on my friends B15 sentra, I used 3rd. gen Max rotors w/Maxima calipers. We found out the dimensions from the FSM that the 2k Sentra SE ( w/sr20de) are the same size rotors and same calipers as 3/4th Maxima`s. Being that the B15 Spindle is the same on the SE-Spec V, The Calipers are the direct bolt on w/ the rotors drilled. I`m searching for Brembo calipers from a Spec V to d the test fit on my 3rd gen.
GAMERA30 is offline
Quick Reply: THE BBK PiCTURE THREAD (Show off your BBK setup here)
