Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-23-2006, 07:35 PM   #1
Tha Snatcher
Iron Scimitar's Avatar
Q45 Caliper/13'' Cobra Rotor BBK Upgrade Write Up
Parts used:
*90-96 Infiniti Q45 front calipers
*Hawk HPS Pads (HB415F.583 Will also fit 92-97 Infiniti J30 front calipers)
*Technafit SS Braided Lines (direct fit for the calipers)
*13'' Ford Mustang Cobra rotors - RTP Zinc coated
*Jeff's brackets and centering rings (the brackets are designed for the 300zx calipers but will work w/ this upgrade. The centering rings are made for 13'' Cobra rotors. The rings center the rotor.)
*Nuts/bolts/washers (Purchased from Home Depot)
4 Hex Bolts (12mm-1 75x40mm)
4 Lock washers (12mm)
4 Lock Nuts Nylon Insert (12mm-1 75)
Instructions on how to remove your front calipers + rotors found here: http://www.motorvate.ca/mvp.php/300
*FYI* I have 18'' wheels w/ a 30 offset w/ a 1'' lip. This upgrade will not clear stock 4th gen wheels!!
After reading on how to remove the rotor + caliper, continue below...
*Dust Shield Removal*
The dust shield will only accomodate the stock Maxima rotor. In order for your new rotors to fit, you'll have to either...
a) Bend the lip back until its straight
b) Cut the lip off
c) Remove the dust shield entirely
Removal of dust shield
Once the shield is taken care of, use the bbk bracket (dogbone looking piece) IN FRONT of the knuckle. (pictured)
(this is behind the hub. The new hardware is on the right. The stock Maxima hardware is on the left.)
Once the bracket is in place, use the new hardware to secure it. Insert the bolts from the front and secure it w/ a nut.
Top view of the bracket + bolts, notice the lockwasher on the right side.
Iron Scimitar is offline   Reply With Quote
Old 04-23-2006, 07:36 PM   #2
Tha Snatcher
*Test Fit the Rotor and Torque Member & Rotor*
Mounting the rotor onto the hub and securing the torque member onto the bracket.
1) Place the new centering ring onto the hub for the new rotor to sit on. Make certain its flush w/ the hub.
2) After the ring is in place, put the 13'' rotor on. It should sit on the hub w/o trouble. Make sure the dust shield isn't touching the rear of the rotor.
3) Place the caliper bracket in front of the remaining two holes of the bracket and secure w/ either the stock Maxima hardware or new hardware.(17mm bolts)
4) Load the new pads into the torque member.
*Mounting the Caliper*
Rotor, caliper successfully mounted.
5) Place the new calipers onto the torque member and secure it w/ the caliper pins. (14mm bolts)
6) Re-attach the brake lines.
7) Check that all bolts are properly torqued and re-mount tire.
8) Check to see if the rotor spins freely. If not, check your wheel spokes for contact w/ the caliper. Grinding of the caliper might be necessary.
If everything is successful, dont forget to bed in those new brakes. Instructions to do so are found here: http://www.zeckhausen.com/bedding_in_brakes.htm
Enjoy!
Old 04-23-2006, 08:10 PM   #3
I support for what?
Send a message via AIM to Mxrider52
What type of wheels will this work with?
__________________
Shift_Individuality
D2 Coilovers, Frankencar midpipe, Popcharger, AE Headlight Mod, Red/Clear Tails
Mxrider52 is offline   Reply With Quote
Old 04-23-2006, 08:30 PM   #4
Tha Snatcher
Quote:
I have 18s w/ a 30 offset. It also has a 1'' lip. Sorry i didn't include it in the write up. I'll add it in. Thanks
Old 04-23-2006, 08:38 PM   #5
I support for what?
Quote:
Originally Posted by Karim
I have 18s w/ a 30 offset. It also have a 1'' lip. Sorry i didn't include it in the write up. I'll add it in. Thanks
How much clearance do you have? This wont work with stock 16s will it?
__________________
Shift_Individuality
Old 04-23-2006, 08:41 PM   #6
Tha Snatcher
I seriously doubt it will work w/ the stock 16. I wouldn't bet on it.
Old 04-23-2006, 11:08 PM   #7
ZHP
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
Interesting.
If you don't mind me asking. How much did the Q45 calipers run you?? I have 13" Cobra rotors, looking to get some Z32 calipers. I have read some of the info on the Q45/J30 caliper thread in the General forum.
I may just consider the Q45 setup. How does this setup feel?? And is it possible can you compare it to a Z32 caliper setup?
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
4DRSpeed.com - It's coming!
4DRSpeed is offline   Reply With Quote
Old 04-24-2006, 12:03 AM   #8
Droppin logs
D-Bo's Avatar
Send a message via Yahoo to D-Bo
Excellent write up Karim!
Somebody sticky this stat!
D-Bo is offline   Reply With Quote
Old 04-24-2006, 04:22 AM   #9
Tha Snatcher
Quote:
Originally Posted by 4DRSpeed
Interesting.
I got some Q45 calipers from a junkyard thru a local ORG member for $40. Then i bought some remanufactured calipers from AutoZone for 170/pair. I exchanged the junk calipers and got $80 back, If I remember correctly.
The setup feels miles beyond what I had before. The stopping power is tremendous. Sorry, i can't give you any comparisons to the Z32 setup. I've never been in a car w/ the Z32 setup. This upgrade will work w/ the Z32 calipers as well as the Q45/J30 calipers. This is what Jeff's BBK brackets were meant for in the first place.
Thanks bro This is my 1st write up!
Old 04-24-2006, 05:05 AM   #10
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
Well done. I assume you have no pics of the hub centric rings?
Zack342 is offline   Reply With Quote
Old 04-24-2006, 05:21 AM   #11
Tha Snatcher
Quote:
The Cobra centering rings? Sorry, I do not
Old 04-24-2006, 07:53 AM   #12
Torque Member
Did you have to grind any material off the inside of the torque member to accomodate the new rotor? Are these rotors thicker than stock maxima rotors? Good write up!
Chris99SE is offline   Reply With Quote
Old 04-24-2006, 08:09 AM   #13
Tha Snatcher
Quote:
Nope, I didn't have to grind the torque member at all. Only the removal/cutting of the dust shield is necessary. The 13'' rotors are thicker than the stock Maxima rotor.
Old 04-24-2006, 08:37 AM   #14
That is good to hear since i do not have the tools for grinding. So did you use your stock maxima torque member then?
Old 04-24-2006, 09:01 AM   #15
Zack342's Avatar
Jeff's brackets look beefy....i just wish i coudl get a picture of the rings. I am just waiting to decided on weather or not is should get this kit. How do you feel about this setup Karim. Do you think its safe? knowing what the rings look like and the fact your rotors centering depends on them?
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Old 04-24-2006, 09:10 AM   #16
I'm needing a caw
Jeff92se's Avatar
Once the rotors are centered, they are then clamped down with the lug bolts. I don't see why they are such an issue with you zach.
Jeff92se is offline   Reply With Quote
Old 04-24-2006, 09:31 AM   #17
Tha Snatcher
I feel totally safe w/ this setup. I've had it on since 3/28 and i went autocrossing the week after I got it installed.
I used the torque member that came w/ the Q calipers.
__________________
Old 04-24-2006, 09:41 AM   #18
SHIFT_OUTTA DA MAX
BoominChu's Avatar
good write up, but you for our plug, f5f5f5f5
RedlineMax did the work
BoominChu is offline   Reply With Quote
Old 04-24-2006, 01:14 PM   #19
I'm needing a caw
Jeff92se's Avatar
Thanks Karim, DaMax and RedlineMax for this excellent writeup. I've been receiving PMs for my brackets and rings. Just to let everyone know, these parts are on order as we speak. It "should" be this or next week that they will be available. Prices have gone up but I'll be holding my $90 shipped price for both items for this run.
Old 04-25-2006, 07:40 AM   #20
ZHP
4DRSpeed's Avatar
I really like the idea of getting some cheap ones from a junkyard and exchanging them for Autozones. I just found some Q45 calipers locally for $35/each. I think tomorrow I am going to pick them up.
Now I'll just need the rings, brackets, and lines, Jeff!!
__________________
Old 04-25-2006, 08:56 AM   #21
Tha Snatcher
Actually, if u wanna try it....I'd get any old calipers you can get your hands on and exchange them for AutoZone remanufactured ones. When i exchanged my calipers, they didn't check the calipers i returned (even though they were the correct calipers.) The guy just took the calipers off of me and gave me my new ones Next time, i'mma snatch some calipers off of a Civic or something
Old 05-01-2006, 09:00 AM   #22
I'm needing a caw
Jeff92se's Avatar
How do you like the setup Karim? Especially with a few hundred miles on them?
Old 05-01-2006, 10:16 AM   #23
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Very interestd in this setup, great write-up.
__________________
Fr33way™ is offline   Reply With Quote
Old 05-01-2006, 10:49 AM   #24
Tha Snatcher
Quote:
Thanks man. I tried to make it understandable for everyone, especially ones like me that are non-technical. First write up too!
Quote:
One concern, when im travelling 60+mph and i apply the brakes it feels that one of the calipers isn't clamping as much as another. The car doesn't 'dive' evenly. One side 'dives' lower than another. It doesn't do it all the time. I topped off my brake fluid and rotated my tires. Other than that, the brakes feel solid.
Old 05-01-2006, 12:01 PM   #25
Send a message via AIM to MaxGordon7
might have a stuck caliper bracket slide. My car use to pull to the side, thought it was the caliper but one of the pins rusted into the rotor backet.
MaxGordon7 is offline   Reply With Quote
Old 05-01-2006, 12:20 PM   #26
Tha Snatcher
Quote:
Are you talkin about the caliper pins? I remember them being greased w/ caliper lube before it was installed.
Old 05-01-2006, 12:52 PM   #27
Q45 Calipers = 1 piston VS Z32 Calipers = 4 piston
MAXRB8 is offline   Reply With Quote
Old 05-01-2006, 12:54 PM   #28
I'm needing a caw
Jeff92se's Avatar
Um no. J30/Q45 twin piston.
Quote:
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Old 05-02-2006, 10:21 AM   #29
I'm needing a caw
Jeff92se's Avatar
yeah but it wouldn't hurt to check of this assembly is moving back/forth freely. It's what I would suspect first. Maybe unscrew the two bolts and see if the accordian pins slide back and forth easy.
Or try rebleeding the side that "doesn't" dive and check that side's slide pins also
__________________
Sold Jan 14, 2006'
Mod list:
Old 05-09-2006, 06:02 PM   #30
michaelnyden's Avatar
Send a message via AIM to michaelnyden
so why are the Q45 calipers $444 from pinnaclenissan...but the J30 ones are $156? aren't they the same?
michaelnyden is offline   Reply With Quote
Old 05-09-2006, 06:05 PM   #31
Zack342's Avatar
Quote:
Because they are not the same.....I looked at a ton of J30 calipers when i was in the Junkyard and compared them to the calipers from the Q i got while at the Junkyard they are not the same. One way of identifing the Q calipers is they have sumitomo stamped on the top.
__________________
Old 05-09-2006, 07:38 PM   #32
ZHP
4DRSpeed's Avatar
Hey Karim.
What brand of calipers did you get exactly? I searched on Autozones website and they have a few different brands.
Fenco
Cardone
Beck Arnley
__________________
Old 05-10-2006, 03:28 PM   #33
but they are the same design? twin piston, they use the same exact pad too...so you have to wonder why such a huge price difference?
so with the caliper extension bracket, this is a direct bolt on to the 13" rotors with rings? how thick are the cobra rotors? what thickness were the calipers originally supposed to be clamping on the J30/Q45?
lastly, by any chance has anyone weighed their stock calipers vs. these J30/Q calipers vs. Z32 ones?
Old 05-10-2006, 04:46 PM   #34
Tha Snatcher
Hey Karim.
Fenco
Cardone
Beck Arnley
I forget what 'brand' they where. I think it was Beck Arnley. Be sure that the calipers say SUMITOMO on the top.
Old 05-10-2006, 04:49 PM   #35
Tha Snatcher
I haven't seen a set of J30 calipers so i couldn't tell you. Zack knows more about it than I do.
With the caliper extention bracket, it IS a direct bolt on to the 13'' rotors w/ rings just like i described in this write-up. Sorry, i dont know the thicknesses of the rotors nor the weights or the calipers.
__________________
Old 05-17-2006, 11:04 PM   #36
I'm needing a caw
Jeff92se's Avatar
I have the brackets/rings on sale now. $110 shipped. "Jeff_Iwata@yahoo.com" is the paypal. Give me the who, what and where if you want to buy. 2-3 sets are already presold
Old 05-19-2006, 06:33 PM   #37
ZHP
4DRSpeed's Avatar
Well I went to work on the right front today.
Having a tiny issue. The rotor seems to rub slightly against the torque member. I'm thinking when I mount the wheel though the rotor will center itself better and will not rub. Did anybody have this issue?
When I hold the rotor straight against the hub its fine, so maybe it won't be an issue.
I am having a hell of a time tryin to break the nut loose for the break lines so I can put my SS lines on.
Also I tried using my Maxima torque member and it just was not going to work. The torque member is too small I don't know how you can run with it on. It just rubs against the rotor. I couldn't even slide the thing on. Thank god I had the Q45s.
Won't be able to work on it tomorrow . Hopefully Sunday. I was out in the rain today workin on it Well it was sunny then the clouds rolled in and god said "Fck You".
Just curious how close your rotor is to the Qs torque member, because for me its a close call.
__________________
Old 04-30-2007, 08:22 PM   #38
I'm needing a caw
Jeff92se's Avatar
Karim? Note. I edited my post to reflect the higher price. I've been referring tons of people to this thread.
Old 05-02-2007, 08:16 AM   #39
very nice. need to do this.
Maximeltman is offline   Reply With Quote
Old 07-10-2007, 10:18 PM   #40
Maxtank's Avatar
Send a message via AIM to Maxtank
Bump
Jeff - Those parts still available? I'm trying to get these parts together.
__________________
99 SE-L | Super Black |5 Spd.
'05 Xterra - Daily Driver (yeah, it's yellow)
NEED - Drivers side Q45 Bracket/torque member
Maxtank is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
