Blue Smoke, PCV and Valve Cover
Been noticing a blue tailpipe smoke on remote start, like an oil burn-off for a few seconds, and almost daily.
weeks went by and decided to pull front 3 spark plugs. … not good!
Spark plugs Threadings glistening w oil, plus burnt porcelain.
ordered front and back VC online for under $90 and comes w everything ( gasket, seals, bolts and pvc), and new spark plugs from stealership.
also Replaced the VC-to-VC vacuum hose as a crack noticed.
surgery lasted about 3 1/2 hours.
culprit : stuck pVC valve.
I firmly believe that the PCV valve is neglected during routine maintenance, and easily forgotten. Until there is a problem, like you experienced, no one pays attention to the PCV.
My household has owned VQ35 Altima and Maxima since 2007. I use spray carb cleaner to clean the PCV every 25,000 miles.
🤜🏽cleaner worked….🤛🏽
hassanqadir
18
11-04-2011 08:49 AM
hassanqadir
07-03-2008 08:41 AM
paralyse
04-21-2005 05:43 PM
Ladzio
12-24-2004 09:21 PM
