Car doesn't always start. Brake light switch or a fuse?
Ok guys, so I've been having a problem with my 2016 maxima. Started out, it wouldn't start a few times. I started it using my remote, then could get into it and drive. That lasted about 2 days. Then I Googled the symptoms and found it could be the brake light switch above the brake peddle. Bought a new one, replaced it. Car started a few times, then nothing. Sometimes it would go into park, other times it wouldn't. So, then I figured it was a fuse. I opened the fuse box inside the car and looked at the description of which fuse is what. There's a brake light fuse that I cane pull out and its next to an extended storage fuse(?) So, what is my next step? Can I go to O'Reillys and get a fuse? Will they help me put it in. Can it be the extended storage thing? I know nothing about cars, and yes, I'm a female so I don't want to be taken advantage of at a shop if it's something that I can possibly do. Any advice is appreciated.
Good luck !
Give a look at your battery. My OEM one was doing the same thing a bit, even though I kept a close eye on the water level. I replaced it with an AGM sealed battery. Never have to worry about those levels again. But the car would not start sometimes at first attempt, and then eventually needed a jump with my battery pack.
Thanks for posting this as I do recall my now traded 2016 early build Maxima Platinum had that type of battery issue at about 30,000 miles on the clock and 28 months old. Mine too would not start on the first try either. I had the dealer replace the battery since the old one was also corroding on the terminals too. These cars' original batteries were not up to the task.
Not a problem. The OCD part of me has always hated how the OEM batteries leave so much leakage behind on the terminals that I went as far as cleaning them off at every oil change (I do my own). To be honest I paid out for a premium aftermarket battery. But it was the one time that I was glad to do it, to get the crappy OEM leakage-prone battery out of my car.
before just throwing parts on it,google ''how to check ect'' and check
like the brake light ,just cross out the terminals to bypass it and check it.
check the relay by turning the ignition on and see if you feel it latching,if not use a test light to check for a hot wire and then a latching wire for power.
Google provided the same info the dealers provide so with my post I actually tested the switched with a voltmeter which all tested good so I then replaced the brake relay switch which was the culprit that not even the dealer had sense enough to check. Just my 2 cents and I know it won't be every one solution but if you changed the switch above the brake pedal and have the same issues then most likely the relay brake switch is bad.
Brake no start
68cutlass425ci
11-23-2014 11:31 PM
raynist
09-04-2006 11:42 AM
1Fast03Max
02-12-2005 05:19 PM
Frank Fontaine
03-31-2003 02:50 PM
