TPMS tire rotation
Old 01-03-2019, 09:15 AM
MoopMeep's Avatar
TPMS tire rotation
I usually have the dealer rotate my tires but
I was wondering, since the display shows the pressure in each tire, when you rotate the tires do you have to do anything to tell the car that the tires have moved to different positions?
Does it figure it out itself?
MoopMeep is offline
Old 01-03-2019, 09:18 AM
MoopMeep's Avatar
FYI: I looked in the manual and it just said to rotate the tires after xxxx miles. I didn't see anything talking about the tpms self adjusting
MoopMeep is offline
Old 01-03-2019, 09:44 AM
Mason Hatcher's Avatar
You also didn't read anything about TMPS needing to be calibrated after tire rotation.
Mason Hatcher is offline
Old 01-03-2019, 10:34 AM
gizzsdad's Avatar
Yes
gizzsdad is offline
Old 01-03-2019, 12:01 PM
NisCal17's Avatar
Don’t do rotation
NisCal17 is offline
Old 01-03-2019, 12:18 PM
lionel2013's Avatar
Originally Posted by NisCal17
Don’t do rotation
All due respect but this is bad advice.
Why do you advise not to rotate tires?
lionel2013 is offline
Old 01-04-2019, 03:07 AM
09Maxima_Sam's Avatar
The Maxima's automatically detect which tire is at which position on the vehicle. After a few minutes of driving the proper tire will show up at the proper location. After I get my tires rotated, the tire shop usually over inflates my tires to 38psi or so. So therefore when I get home that evening, I let the tires rest and cool, and check the cold tire pressure the next morning, and adjust the tires to 33 cold pressure in relation to the current temperature before I leave for work. This assures that not one tire is higher pressure then the other. With this process the tires never get further than 2 psi within each other while driving. Now if we have exceptionally cold weather, I will observe the initial pressures to make sure they are not too low, but they rarely get below 32 PSI.
09Maxima_Sam is offline
Old 01-04-2019, 06:14 AM
compyelc4's Avatar
Don’t do rotation
One of the most misguided statements I have ever heard on this site with regard to tire maintenance. Please site authoritative references to back up your advice.
I have heard of "can't rotate" such as with different size tires in front and back, but never "don't rotate".
compyelc4 is offline
Old 01-04-2019, 02:14 PM
robtroxel's Avatar
Well said,
helps you stay away from "chonga-chonga" noise your tireswill make when the rotations are not done
robtroxel is offline
Old 01-04-2019, 06:34 PM
lightonthehill's Avatar
The TPMS system on the 8th gen is rather impressive. On my 6th gen, I did well to keep the four tires within two psi of each other. But with this 8th gen, I have, with no great effort, been able to have all four tires read the exact same psi over 90% of the time. I began by slightly overinflating all four tires, then let the car sit overnight, then carefully letting out air until all four tires had a psi of exactly 37, which, over decades of driving Maximas, I have found to be the optimum psi for my particular driving style (best control during maneuvers, most even tread wear and longest tire life) I am a very active driver, so most drivers will probably find their best psi may be lower, say 34 or 35.
I do monitor and record my tire wear. I measure the tread depth in each groove of each tire every three months, and if the wear shows any sign of becoming uneven, I take immediate action to correct the issue. ****? Yes. But I am often **** about my car.
lightonthehill is offline
reswedberg
09-19-2018 04:30 AM
TooTawl
29
12-07-2011 03:51 PM
jsmithsole
Tires and Wheels
10-19-2005 08:16 AM
Enduro
01-30-2001 10:54 AM
Quick Reply: TPMS tire rotation
