Usb port slow charging?
I plugged it in for 30min and when I check the battery it's still at the same percentage. When I first bought the car it was fine but now both port are acting up. I have to use the cigarette adapter with usb port to charge it.Anyone with the same issues? Thanks
I assume that your phone was under alot of load while charging.
but if it was not on speaker, bluetooth connected with car playing music, or on navigation, i'd suggest what they ^^ said about getting a "better" charger.
and those two ports are picky, they like what you plugged in first most of the time.
Oddly, I just started having this same problem. I plugged my phone in yesterday when it was at about 40% battery left. After a 2 hour drive, with the phone plugged in the whole time, it was at 20%.
With carplay, i was listening to music and using maps -- but I've always done that and still the phone would charge up nicely.
Only difference for me is an update from ios 10 to ios 11. Has anyone else noticed a change in charging after that upgrade?
I suppose it could be related to the upgrade of apple maps in ios 11. I never had the problem before -- and I almost always have maps on when i'm driving.
i don't know about your phones, but my lg g5 (type-c usb) has the option of selecting what the connection will do: charge the phone, media file transfer, be as a charger to another unit, and two other unnecessary things. and it is sometimes annoying because i forget to check what it is doing after i plug the usb.
just a thought.
just a thought.
I have a Samsung galaxy s8 and I've tried different cords with no luck. Different phones and cords also no luck. I do see the display to charge or music etc with no luck either I will call nissan up regarding this issue
just a thought.
just a thought.
just a thought.
just a thought.
These USB ports are way under-powered by today's phone standards. Especially if you have a phone that has a USB C port. Your best bet is to get a car charger with enough amps or volts for your phone. Unfortunately there is no longer a single standard across USB charging.
Since a USB port has a multi-function design, the one in the Maxima is intended as a communications port, to play your tunes from over the car's audio system, NOT a charging port. For charging, get something that plugs into the cigarette lighter for the higher-current draw that phone charging requires.
Well, that sounds great, but CarPlay requires the phone to be plugged into one of the USB ports.
To be clear, for an entire year, my phone charged perfectly while plugged into the USB port while at the same time playing music and using apple maps. It worked great. No problems.
After an upgrade to iOS 11, the phone no longer charges. I was just wondering if anyone else is having the same problem and perhaps found a fix. I've tried rebooting the phone, using a different cable -- neither of which made a difference.
I did talk to another Maxima owner that is having the *exact* same problem (ie. phone charged fine in the USB port until upgrading to iOS 11). While the evidence is still anecdotal, I'm guessing a problem with the OS upgrade.
I started to have the same issue about a month ago with my Note 5 and now that I switched over to the Note 8, still having the same issue. I always clear my recent apps to make sure nothing is draining the battery before I put it on charge. I did however notice that if I drive in direct sunlight, the battery percentage continuously drops even while charging.
I'd love to use the cigarette lighter port again but it's being used by the dash cam now. Sucks this car only has one.
Also I recommend hard wiring your dashcam into the fuse box. Requires no tools. I recommend this: http://www.thedashcamstore.com/installation-kits/
Similar kits available on amazon...
= Dual Car Cigarette Lighter Splitter Charger Power Socket Adapter 12v Auto Outlet
