LED Turn Signals
Old 11-13-2015, 05:25 AM
spidgeon's Avatar
LED Brake & Turn Signals
Has anyone changed their brake and turn signals to LED yet? I keep seeing this on other cars and love the look. Which bulbs did you use, brightness, etc. Have you experienced any issues?
spidgeon is offline
Old 11-23-2015, 05:30 AM
spidgeon's Avatar
Anyone do this yet?
spidgeon is offline
Old 11-23-2015, 08:04 AM
doctorpullit's Avatar
Nope. I may do the reverse lights and then I'm done. For some reason, I thought the brake lights were already LED. Is it just the tail lights?
doctorpullit is offline
Old 11-23-2015, 03:50 PM
spidgeon's Avatar
Only the 3rd brake light is LED. There are two separate halogen bulbs, one for the brake and one for the turn signals. Both are the 7440 bulbs. I saw an Infiniti Q50 at an intersection today with the turn signal on and just loved the look. With all the tech in the Maxima, I'm shocked there wasn't LED brake and turn signals already in the Platinum.
spidgeon is offline
Old 11-23-2015, 09:33 PM
If you find LED bulbs to use and replace yours, please post the results.
Old 11-24-2015, 04:07 AM
jinzen's Avatar
Retrofit Source sells white or amber 7440 LED bulbs which I'm sure will work well but are $35 for a pair, so $70 to replace all the brakes and turn signals.
I might do it, since those bulbs are usually very easy to replace.
jinzen is offline
Old 11-24-2015, 04:09 AM
jinzen's Avatar
Spidgeon, can you post all of the bulb sizes for the ones you've replaced?
License plate
Fogs
Front Turn Signals
I am most likely getting white LEDs for the first two and Amber for front turn signal, which I did in my Evoque and it worked well.
jinzen is offline
Old 11-24-2015, 10:31 AM
spidgeon's Avatar
License plate
Fogs
Front Turn Signals
Turn signals I haven't done yet, I'm researching which bulbs to use for that now. If you have suggestions for turn signals, please post. Below are the bulbs I have put in.
Fogs - H16s
License plate - 921s
Reverse lights - 921s
spidgeon is offline
Old 12-10-2015, 02:30 PM
solariis's Avatar
Fogs - H16s
Any updates on what size bulb for turn signals? I cant seem to it anywhere online.
solariis is offline
Old 12-10-2015, 06:08 PM
spidgeon's Avatar
Here's the link to my post about changing the turn signals
https://maxima.org/forums/8th-genera...placement.html
spidgeon is offline
Frank Fontaine
10-30-2015 06:13 AM
MaximaGuy14
10-22-2015 01:38 AM
DaveJ
10-20-2015 09:04 AM
ColdCananda
10-19-2015 10:00 AM
FanaticMadMax
10-15-2015 11:19 AM
Quick Reply: LED Turn Signals
