Recall Anounced
Old 10-13-2018, 06:55 PM
  #161
lindros2's Avatar
Lindros2 - If the dealer is baiting you with an 'intelligent cruise control' recall, and your Maxima version does not have intelligent cruise control, he is either misguided or abusing the system.
But just to be sure you don't have any trouble, I wanted to confirm that you were aware (as I think you said you are are), that ALL versions of the 8th gen Maxima have ABS systems by government requirement, and some of those ABS systems were installed with faulty pump seals, allowing fluid to leak out onto a hot surface, starting fires. Only your service tech can read the pump serial and determine if your pump is on the pump recall list.
You might should call your dealer and tell them you received a recall notice for intelligent cruise control, which your car does not have. He may have confused two different recalls. The fact this is the SECOND recall for the ABS pump seals further confuses the problem.
It’s not me bro. READ ABOVE.
And do they all have ABS?
I’ll remember to tell Bosch that this week, when I meet with with them. #truestory
lindros2 is offline
Old 10-13-2018, 07:00 PM
  #162
Lemonhawk's Avatar
As I said the Dealer did not look at the car, his computer gave a code that said the car was subject to the safety recall and was not drivable, hence he gave me a loaner. The ABS light only blinks on startup, the VIN # does not show up on the web site. So, somehow based on production date (I think) their computer flagged the car. So Nissan must know from the production date which cars are suspect. They were going to have the car for the whole day for a 1hr GEL lighting install so if they needed to look at the pump serial # they could have done that then. Instead when I made the appointment, they indicated that they were going to give me a loaner because of the recall and we just have to wait for the parts. If it was a matter of inspecting it first, they certainly would not have given me a loaner
Lemonhawk is offline
Old 10-13-2018, 07:26 PM
  #163
Polarisdb's Avatar
Yeah, it was me.
I got the card in the mail from the dealer and nothing from Nissan corporate at this point. It only mentions a "possible SAFETY RECALL" and nothing specific. That's why I was posting here to see if a new issue popped up since my VIN was clean when I looked it up for recalls. And FWIW, the possibility that this was ABS-related was pure speculation on my part.
Polarisdb is offline
Old 10-14-2018, 10:24 AM
  #164
lindros2's Avatar
Originally Posted by Polarisdb
Yeah, it was me.
This isn't good. 7 recalls, and two safety concerns re: FUEL LEAK after an accident.
https://www.nhtsa.gov/vehicle/2016/N...4%252520DR/FWD
Overall Front Star Rating Front Driver Side After the frontal impact barrier test, 20 oz. of fluid leaked from the fuel system during the static rollover test. A fuel leak can be a fire hazard. Details on the 49 CFR Part 573 filing from Nissan on this vehicle can be found at http://www-odi.nhtsa.dot.gov/owners/...E03K4847AGNFR3
lindros2 is offline
Old 10-14-2018, 10:30 AM
  #165
lindros2's Avatar
Just go to NHTSA.gov, people. When I entered my VIN, it answered all of my questions (and highlighted spelling errors for giggles).
1 Recalls associated with this VIN
Sep 07, 2018
Manufacturer Recall Number: R1807
NHTSA Recall Number: 18V-601
Recall Status: Recall Incomplete
Summary
IN CERTAIN VEHICLES AFFECTED BY THIS RECALL, THE ANTI-LOCK BRAKE SYSTEM (ABS) ACTUATOR MAY LEAK BRAKE FLUID. IF THIS OCCURS, THE ABS WARNING LAMP WILL ILLUMINATE AND REMAIN CONTINUALLY ILLUMINATED ON THE INSTRUMENT PANEL.
Safety Risk
IF THIS CONDITION IS IGNORED, THE LEAK CAN POTENTIALLY CREATE AN ELECTRICAL SHORT, AND IN RARE INSTANCES, MAY LEAD TO A FIRE.
Remedy
YOU MAY HAVE RECIEVED PRIOR NOTIFICATION TO BRING YOUR VEHICLE INTO THE DEALER FOR REPAIR. IF YOU RECEIVED PRIOR NOTICE, OR HAVE NOT, PLEASE BRING YOUR VEHICLE INTO A NISSNA DEALER FOR INSPECTION IN EITHER CASE. YOUR NISSAN DEALER WILL INSPECT THE SERIAL NUMBER OF THE ABS ACTUATOR, AND IF IT IS WITHIN THE AFFECTED RANGE, THE DEALER WILL REPLACE THE ABS ACTUATOR WITH A NEW ABS ACTUATOR AT NO COST.
Manufacturer's Notes
Please contact Nissan Consumer Affairs at (800) NISSAN-1 (or 800-647-7261) for additional questions. Monday - Friday 7:00am to 7:00pm CST
If the manufacturer has failed or is unable to remedy this safety recall for your vehicle in a timely manner,
please contact the NHTSA Vehicle Safety Hotline at: 1-888-327-4236 or TTY: 1-800-424-9153 or file an online complaint with NHTSA.
lindros2 is offline
Old 10-14-2018, 10:31 AM
  #166
lindros2's Avatar
Originally Posted by Lemonhawk
Well the Dealer is holding my car hostage until the recall part comes in. I'm stuck driving an Altima loaner. I don't think they physically checked anything, I was in for something else when he said the car had some sort of code that indicated the pump needed replacing and they would give me a loaner. ABS lite does not say on - only blinks on startup. Has anyone had there car up in flames?
FYI - on the recall page (NHTSA.gov), look at this:
lindros2 is offline
Old 10-14-2018, 10:37 AM
  #167
Polarisdb's Avatar
Mine:
Old 10-14-2018, 11:31 AM
  #168
lindros2's Avatar
Mine:
then you’re fine, and your dealer is a crook.
lindros2 is offline
Old 10-15-2018, 05:32 AM
  #169
Polarisdb's Avatar
I think crook is a little strong since the postcard said it was a "possible" safety recall and they would at least be giving me a free oil change. I've dealt with plenty of sleazy dealers over the years and these guys haven't been too bad (I realize that's not saying much). Their parent company has been gobbling up several local Nissan dealerships though, so the good pricing I got when I bought my car may go bye bye if they control more of the local market.
Old 10-15-2018, 05:39 AM
  #170
lindros2's Avatar
Using a recall to “bait” people to come in is against Federal Trade Commission law. This is why there are online VIN lookups - otherwise every “possibly affected” Maxima would need a clean bill of health before being sold as used (dealers can’t have it both ways - are they inspecting every new and used car on the lot? Absolutely not).
Recall work is a huge profit center.
As is... doubling the money factor on leases (see: Nalley Nissan / Asbury Automotive). Slime bags.
lindros2 is offline
Old 10-15-2018, 09:25 AM
  #171
Polarisdb's Avatar
Huh, I have not heard that before. Do you have a source you could link to?
Old 10-15-2018, 09:31 AM
  #172
lindros2's Avatar
Right here - https://www.consumer.ftc.gov/blog/20...recall-notices
Seriously, why would I make this up?
TEXT:
FTC sues car dealerships for fake recall notices
October 10, 2018
by Seena Gressin
Attorney, Division of Consumer & Business Education, FTCA recall notice for your car or truck signals a serious safety defect that you should try to get fixed quickly. According to an FTC lawsuit, a group of auto dealerships counted on people doing just that when they sent fake mailers marked “URGENT RECALL NOTICE” to more than 21,000 vehicle owners, most of whom did not have recalls.
In the words of one defendant, the mailers were designed to “drive some traffic” to the dealerships’ service departments. According to the FTC, many people who got the notices called the dealerships to find out their vehicle’s actual recall status. Many who called were told they had to bring their vehicles to the service departments to learn their vehicle’s status and, the FTC said, a lot of them did.
lindros2 is offline
Old 10-15-2018, 11:21 AM
  #173
Lemonhawk's Avatar
Mines, done! New "actuator" (ABS Pump) installed. About one day faster that what was predicted here for the part to come in.
Old 10-15-2018, 11:24 AM
  #174
Polarisdb's Avatar
Thanks, good info!
Old 10-15-2018, 07:43 PM
  #175
lightonthehill's Avatar
Thanks, lindros2. Good reference. I may have misread it, because it seemed the guilty dealerships got little more than a slap on the wrist. There should have been significant fines for such greed and dishonesty with public safety involved. The worst thing is that such antics both confuse an important issue and set up customers for work that may not be tied to safety, or may not actually be needed at all. This type dishonesty also adds to the ongoing problem of busy folks that just don't feel they have the time to take off work and take their car to the dealer for a recall they don't quite understand. The longer those folks 'get away' with not acting on recall notices, the more apt they are to ignore them in the future, possibly to their great peril.
lightonthehill is offline
Old 10-16-2018, 01:15 PM
  #176
lindros2's Avatar
Oh wait there are about 50 other stories about that, too... Too tired to post/search, but you can do it.
lindros2 is offline
Old 10-16-2018, 05:32 PM
  #177
compyelc4's Avatar
I received this notice today for my 2017 Max SL: Nissan records indicate that your vehicle is subject to a safety recall. Nissan is currently preparing parts to remedy your vehicle. In the meantime, Nissan is asking you to follow the following precautions.
Reason for Recall
In some vehicles affected by this recall, the Anti-lock Brake System (ABS) actuator may leak brake fluid. If this occurs, the ABS warning lamp will illuminate and remain continually illuminated on the instrument panel. However, if this condition is ignored, the leak can potentially create an electrical short, and in rare instances, may lead to a fire.
What You Should Do
If the ABS warning lamp in your vehicle (shown to the right) illuminates continually for more than ten (10) seconds after engine start:
  1. Please stop driving your vehicle immediately and call Nissan Roadside Assistance at 1-800-225-2476 to arrange towing your vehicle to a Nissan dealer at no cost to you
  2. Park your vehicle outdoors, away from other vehicles or structures
Anti-lock Braking System (ABS) warning light
If your ABS warning lamp is continually illuminated and you require alternative transportation while your vehicle is being remedied, your Nissan dealer will make appropriate arrangements at no cost to you.
You may find your nearest dealer using this link: Dealer Locator
Next Steps
In the coming weeks, you will also receive a recall notification letter with further instructions. Until then, if you have questions regarding the safety recall, please visit www.nissan-usa.com/recalls-vin#/ or contact Nissan Consumer Affairs at (800) 867-7669.
Nissan is committed to the safety and security of our customers and their passengers. We are indeed sorry for any inconvenience this may cause you.
Sincerely,
Consumer Affairs, Nissan North America
compyelc4 is offline
Old 10-16-2018, 08:14 PM
  #178
240tomax's Avatar
I phoned Nissan consumer affairs in Canada to inquire about the ABS pump recall and was informed that my vehicle has been recalled. Called my dealer which is two hours away to arrange for the recall while other warranty work is being performed. They said that they have to check the pump to see if it is part of the batch that could potentially leak. Unfortunately, Nisan Canada will not allow the dealership to have the required replacement parts on hand should this happen, as they would then need to order them. And if it is deemed to need replacement they can't release my vehicle until it is repaired. Not a big deal if I lived locally, but I don't. This would require me to return at a later date. Going to contact consumer affairs tomorrow and ask WTF.
240tomax is offline
Old 10-16-2018, 11:26 PM
  #179
Just as info, U.S. dealers are in the same situation. Not allowed to stock the part. If your pump serial is on the recall list, they cannot let you drive the car. My dealer is an hour away, so they paid for me to rent an SR Maxima for the week or two while they waited for the replacement pump.
So the only question in my mind is why are dealers not allowed to stock a replacement part which, if it goes bad, the car cannot be driven? I'm sure there is a reason, but it escapes me.
Old 10-17-2018, 04:55 AM
  #180
lindros2's Avatar
Ditto to all of these. Replacement parts = could be a supply issue, or just a logistics issue, or something else.
lindros2 is offline
Old 10-17-2018, 09:49 AM
  #181
Gator5000e's Avatar
Dealer found nothing wrong
I took my car to the dealer this morning. They said they inspected the car per the recall notice but determined that nothing was wrong and that nothing needed repair or replacement.
Does this sound correct? Should they have replaced the parts no matter what? I’m confused so thanks for any thoughts.
Gator5000e is offline
Old 10-17-2018, 10:19 AM
  #182
lindros2's Avatar
You're good. Here's why:
1. Your VIN was flagged as "part of the campaign" (due to configuration/features/options).
2. However, dealers have to actually inspect the SERIAL NUMBER of the part (ABS actuator).
3. Yours is okay; nothing wrong.
lindros2 is offline
Old 10-17-2018, 10:48 AM
  #183
Gator5000e's Avatar
Great. Thanks so much for the explanation!!
Old 10-17-2018, 02:27 PM
  #184
Lemonhawk's Avatar
240tomax, my dealer gave me a free loaner while waiting for the parts, you should check but its likely that they have to give you a free loaner, as they they can't just keep your car with out compensation.
Old 10-17-2018, 06:40 PM
  #185
240tomax's Avatar
They are providing a loaner (actually overall this dealer is awesome)...but I don't want to have to go home and then come back a couple days later with a round trip of over 4 hours each time.
240tomax is offline
Old 12-25-2018, 08:15 PM
  #186
240tomax - It is tough that you live so far from your dealer. I had that situation when I lived in the southern Arizona desert back in the 1950s (not driving Nissans at that time, of course), and it was not fun. I now live less than an hour from four Nissan dealers, and less than two hours from nine or ten Nissan dealers. This is nice when I am ready to buy a new Maxima, because I can keep up with the inventory for all those dealers, and if exactly the Maxima I am looking for appears in the inventory of any one of those dealers, I simply call my local dealer and make an offer on the car I want, and if he accepts, he has the car transported to his lot and preps the car for me. I purchased my last two Maximas that way.
You should not be faced with this situation. Nissan should allow dealerships to stock any part without which the car is not to be driven. That strange situation resulted in my being able to drive a new SR for two weeks at Nissan's expense, but if I was not retired, I would have not been happy with that time-consuming situation.
Old 01-09-2019, 12:31 AM
  #187
I just came off a three day over 1,000 mile trip Monday, had my 2016 Platinum detailed Tuesday morning, and took it to my dealer for oil change, air filter, cabin filter, tire rotation, etc on Tuesday afternoon. When my car was ready for pickup, the lead mechanic (whom I have known over twenty years at two dealer locations) was waiting with my writeup tech and service manager and told us he had checked the serial number on my ABS pump and my car did not need a new ABS pump. I was relived, because, had the pump needed to be replaced, they said it would have taken them three days to get the new pump in hand, and I would have had to rent a car (at their expense) just as I did last year during the first version of this recall.
While waiting during the servicing of my car, the owner of my dealership (he now owns four Nissan dealerships, a Kia dealership, and a Toyota dealership) showed us a loaded Lexus LC 500 he was selling at an excellent price. My wife and I loved the interior and the side appearance, and the view from behind was very impressive. But not the front grille. The car was in immaculate condition. The dealership owner had driven the car for one year. His MSRP was just over $99K, and he was letting it go for $84.9K. It was very tempting, but we could not get past the front grille, and that kind of money would buy each of us a loaded Maxima Platinum with change left over, so we did not bite. Someone will get that really impressive car at a good price. But the LC 500 is not really me. I'm a Levis guy, not an Armani gentleman. I'm much too frugal (and cheap) to be seen in that luxurious car.
Old 01-09-2019, 12:49 PM
  #188
robtroxel's Avatar
Ahh yes, sensibility prevails! I am thinking the same way. I just hate having that much dough sitting out in the parking lot. The LC500 is a great car but Toyota needs some styling help with the front end of their cars.
robtroxel is offline
Old 11-15-2019, 08:40 AM
  #189
effinaround's Avatar
Is this a new recall or just a rehash of the existing one?
https://www.bnnbloomberg.ca/nissan-t...nger-1.1348659
reading the article, it sounds like new information was just posted but perhaps that was only for an expansion in scope and the Max was already covered.
effinaround is offline
Old 11-15-2019, 10:42 AM
  #190
Evidently I can't read too well today. I just noticed it is the third time they have done this recall and now are replacing and not just inspecting all the ABS actuator pumps.
Old 11-15-2019, 11:17 AM
  #191
BrianShaw's Avatar
Nissan Recalls Over 450,000 Vehicles That Could Catch Fire From Brake Fluid Leak
http://on.ktla.com/AsIV3
BrianShaw is offline
Old 12-26-2019, 10:06 PM
  #192
The recall notice referenced in BrianShaw's post above that once applied to mostly 2016 Maximas has been expanded to cover almost a half million Nissans. I received the recall notice mentioned in BrianShaw's post last week. Familiar song and dance. If the ABS light stays on more than ten seconds, park the car (NOT inside a garage or building), call Nissan and expect to have the car taken to a dealer for ABS sensor replacement. If the ABS light does NOT stay on for ten seconds or more, you can continue to drive the car, but will still be notified when new ABS actuator pars become available this coming summer, and told to schedule a service trip to your dealer to replace the ABS sensor.
Yes, this is the third recall for this problem, and expands the number of vehicles involved greatly. I will be glad when this merry-go-round finally stops.
Old 04-01-2020, 07:24 PM
  #193
denoose's Avatar
ABS system recall- 2017 SR
My dealer mentioned this issue when I had the last oil change about six weeks ago, and they contacted me today to advise me that the necessary parts are in stock- I am having the ABS system serviced tomorrow- was told it's a four hour job and that a loaner would be available as well.
denoose is offline
spazma7ik
07-29-2015 10:50 AM
Pnjboyzz
04-26-2015 01:26 PM
taz394
02-18-2011 09:20 PM
yelowd
03-01-2005 06:54 AM
JodyBerry
09-13-2002 09:09 AM
Quick Reply: Recall Anounced
