i need help!!!! traction control light stays on whil driving
stupid question, but have you tried turning it off?
Also, are any other lights on? Many times, the traction control light comes on when you have other lights on as well (like a check engine light).
Check for codes.
Check for codes.
I have been driving since 1949, and at some point, I have had to add brake fluid to every one of my many vehicles. You may have avoided this by having your brakes serviced (at which time, the fluid is automatically topped off), or by having used a service shop for oil changes that routinely tops off all fluids that are not at the 'full' mark.
i love this forum i was just about to call the dealership about my light then read this >> thanks ghozt and other that posted this fix .checked my brake fluid and it was alittle low topped off and no more light thanks guys!!!!
As the pads gradually wear, the hydraulic system has to push the fluid slightly further into the brake lines. Eventually, this begins to take the fluid level in the brake fluid reservoir down to the 'add fluid' line, and the brake alert light and the stability control light both begin to come on, sometimes intermittently, and then steady.
kjlouis
11-24-2018 06:09 AM
MaximaDrvr
08-19-2015 08:20 PM
yat70458
08-03-2015 01:16 PM
