Sponsored by:
Sponsored by:
Disabling Traction Control ?
Old 11-25-2012, 10:15 PM
Rafik Jabbour's Avatar
The other day, I almost got stuck in a muddy surface because of traction control, even when its off, it still kicks in..
Can't we just fully disable it ?
Rafik Jabbour is offline
Old 11-26-2012, 05:06 AM
Akiyukio's Avatar
VDC, or traction control as it used to be called, can be disabled with the switch near the mirror adjustment panel. It should fully disable to the system, except for ABS, which is full time regardless of the whether the VDC system is on or off. You can verify this with a warning light on the dashboard.
Also, our cars have a limited slip differential (according to my dealer, I have yet to confirm it).
How were you driving that caused you to almost get stuck? The VDC system is there to help you, not hinder you...
Akiyukio is offline
Old 11-26-2012, 10:15 AM
I was driving in a wet sandy area that had a soft slope and was inclining up with the system being off but the other warning light that looks like a car sliding showed up blinking on the dash board killing the throttle.
In my previous BMW, if you hold the traction control button for 5 seconds, it disables the entire system.
Old 11-26-2012, 12:32 PM
Akiyukio's Avatar
Most strange, the owners manual does state this:
Might want to get it checked out?
Akiyukio is offline
Old 11-26-2012, 07:33 PM
I want both lights on (which means both systems Traction Control & VDC OFF)
The one on the left = VDC, could be disabled using the button next to the drivers panel on the left.
The one on the right = Traction Control, could NOT be turned off and blinked for me cutting the throttle!
How on earth can you disable it ?
Old 11-27-2012, 05:00 AM
Akiyukio's Avatar
I notice that you have a different year than mine (I have a 2012), I am honestly out of ideas.
Perhaps Nissan changed the system functions?
Sorry, can't help much further, but perhaps other members can chime in?
Akiyukio is offline
Old 11-27-2012, 05:02 AM
Thanks for your reply mate..
Anybody else facing this issue ? mine is a 2011 Maxima designed for GCC countries..
Old 11-27-2012, 02:01 PM
zoemayne's Avatar
he is in dubai i dont know what the requirements (if any) are for traction control there... thats a variable to consider
zoemayne is offline
Old 11-27-2012, 07:29 PM
Alright thats how my panel looks like
And thats what happens and what lights up when I turn the VDC off
Old 11-29-2012, 05:17 PM
bk2k3max's Avatar
According to what I've read in the manual when the VDC Off light is on that means the system is actually off (it's one of those Japanese things, lights on means the system is off, lights off means the system is on).
My car does the same thing as your but not on the Traction Control, the only time that comes on is when there are conditions that affect the car like wet roads, maybe when you take a turn too abruptly causing a side to side shift in the weight of the car too drastic.
This system (VDC) is very sensitive so it interrupts often and the manual says you should drive with this on for most conditions, I actually hate this feature until i need it when it rains.
bk2k3max is offline
Old 11-30-2012, 12:05 PM
eesjunin's Avatar
[QUOTE=Akiyukio;8672157]
QUOTE]
BTW when doing my lights i had the entire front in the air, and noticed that drivers side would not rotate when taking off the lugs. while the passenger was free to rotate.
eesjunin is offline
Old 12-02-2012, 10:25 PM
So still no info on this...hmmm
Old 01-21-2016, 01:51 PM
LouisP's Avatar
Rafik,
have you ever found a solution?
I have the exact same problem!
thanks
LouisP is offline
Old 01-27-2016, 09:59 PM
Maxxx10's Avatar
Originally Posted by LouisP
Rafik,
thanks
I know how to disable the whole system, TCS, VDC, and ABS too.. I will upload a video for that to show you how to do it. Wait for me
Maxxx10 is offline
Old 01-28-2016, 06:55 PM
Maxxx10's Avatar
https://maxima.org/forums/7th-genera...ml#post9092627
See that..
Maxxx10 is offline
Old 01-18-2019, 09:55 AM
Tj Bozich's Avatar
where is the button by I can’t find it
Tj Bozich is offline
Old 01-18-2019, 12:56 PM
Did you go to this link? He shows the button. It's associated with the brake pedal. Here is the link again.
The Wizard is offline
Mala226
02-14-2018 07:11 PM
xydehead
04-07-2016 03:04 AM
ebonyjoy19
01-31-2016 12:35 PM
Tryonetic
09-07-2005 07:41 PM
Jime
04-01-2004 11:11 PM
Quick Reply: Disabling Traction Control ?
