Dash lights wont come on car wont excelerate 09 max
Hello im new to this forum, the question is i bought and 09 maxima car ran good for 2 months the first issue i started having, windows, turn signals etc...wouldnot work found that the fusible link was bad. Replaced work out ok no problems. Now here is the problem im having now with my baby stop at a light i then notice that my dash light and radio started flickering and then all of a sudden my car would not excelerate under 2mph change the alternator still having the same issues with it. What could be the problem and how do i fix it.
I've seen something like this happen with a friend's car. It was on a H22A motor though, but he forgot to bolt down a ground cable which caused symptoms similar to what you're experiencing. Recheck the fuses and connections.
Yes, very indicative of a bad alternator (yeah I know you changed it out but.....) as the regulator is integrated to the alt. Grounds/connections are also problematic. And another question, I really have never seen a fusible link go bad without a fubar type of problem. Do you know what caused that to blow?
To be honest i really dont know what or how it happened only thing i do know my windows and turn signal and seats would not mo e or do anything thats how i found the fusible to be blown.
robsst
09-01-2012 06:43 PM
96maxi
02-16-2011 05:46 PM
ChrisCheezer
02-23-2003 10:23 AM
