opinions on Grounding Kit
ok well stillen and racingline both have grounding kits for the maxima now my question is
Is it worth the $100.00?
whats the difference between those two companies other then the name?
does it really make your car faster? smoother revving? or any other claim they say?
thanks for the help ill be looking forward for a response.
Stillen:http://www.stillen.com/product.asp?i...N&model=MAXIMA
Racingline: http://racinglineperformance.com/sho...&idcategory=22
I cannot speak to the effects on your '09. However, the grounding kit did make my shifts smoother on my '05 and the windows rolled up faster. I would not pay $100 for a kit though. Mine only cost $50 from Active Tuning. I don't see where they have a kit for the 7th gen yet but I'd bet that they are working on it.
Another option is to make a kit yourself. Some folks have successfully gone this route.
I had one on my 06 from activetuning, 2 things I noticed it did was: smoothed out the transmission, the trans had a rough shift that was pretty much eliminated after I put the grounding wires on, and 2nd the ground wires fixed the sluggish rear power windows, I took it back to Nissan cause I thought something was wrong with them but they were fine, .
My 09, transmission shifts as smooth as any luxury car and the power windows are ridiculously fast and smooth.
Thought I was the only one!
I thought I was the only thinking I was crazy, about smoothing the shifts out on a shiftless CVT vehicle....? Maybe I am missing something? I guess we will have to wait for more reviews from those who made the jump and go from there!
I don't think that grounding kits are a complete waste. they will help out in the long run as your grounds begin to corrode and become inefficient. I think that racingline would be a good option if they have them out(always nice to support a local vendor), another good option would be sunautomobile if they have any kits for the max. I had a grounding kit by active tuning and then UPGRADED to the sunautomobile one and it was much better than the active tuning....bigger wire, nicer leads, and seemed better crafted imo.....just my thoughts though
Then only result you will obtain from installing a grounding kit on a 7th gen is loss of money, although if you have a 7th gen money might not be an issue lol. But yea, your cars are too new to benefit from grounding kits. Usually a car benefits from it when its factory wires have faced years and years deterioration, so improving grounds on a 3rd or 4th gen, you might possibly see a difference, not on a new car.
I did one on my 7th gen, mostly just because I wanted to do a decent sized audio system. I figured that increasing the ground was probably a good idea, especially as time passes and factory grounds start to corrode.
On the up side, the car did seem to get a hair more response in the throttle. The windows are a little bit quicker, and there is absolutely no dimming of the lights when I play my stereo at night. Although I could just be imagining things.
If you do decide to do it, the Racingline kit is great and their support was top notch. I'm sure others have good kits too but Racingline would definitely be my first choice if I had to buy again.
that was one of my main reasons...i'm gonna put my JL's into this car and wanted to make sure the extra grounding support would help even though i'm putting in a 1/2 cap to make sure there's no dimming...
also...i think i read somewhere in the 4th gen forums that the ticking noise went away after the grounding kit was put in?...how would the grounding kit cut out the ticking noise????
Did you put one on your 09 yet? I've gone back and forth on this topic and even got my megger out to check on the differential between different points on my Max with not seeing more than a .25 ohm differential (All Doors and trunk closed) One thing I was going to try, is reterminating my battery to chassis ground and no-oxing it when I replace the battery (i've noticed my nominal V dropping a bit and while it could be the ground only, I'll save myself a trip under the hood and take care of both concurrently.
Anyone have an opinion having it installed on the 7th gen?
Smoother idle perhaps or better response? Increase in mpg or brighter lights/crisper audio?
I think the $55 from racingline's website is a fair deal for an engineered grounding kit for our vehicle. I plan on investing in this mod soon.
Hilarious. Not as much hp gain as stickers I bet!
All joking aside, these wires are good for about 1 hp, but you get them for enhanced electric signals in the car through better grounding.
I just bought some from racingline.com and will install them on a weekend. I'm hoping for a +1 mpg increase and brighter headlights.
I had a DIY kit on my 6mt matrix xrs, but I want to try them on the maxima to see how they will work on the CVT.
I'll provide my review when I install them.
yeah i dunno about them being "engineered" or anything, they're just thick wires you can make your own kit if you want. i added the grounding kit to mine cause my battery is in the back so I wanted to make sure my ground is stable and bolted to the chassis in several spots. so for me it serves its purpose of maintaining a stable electrical system for years to come
Maybe someone can help me out... I got the Racingline grounding kit intalled yesterday. I do notice a little better throttle responce (I think). But now my dash computer is all out of wack. The mpg stays at 15mpg (doesnt move). My windows dont go auto up anymore (they go up, but just not "auto"). And lastly my "miles till empty" says 500 miles when i filled up today... usually its maximum around 350 on a full tank) anyone know what could have happened?
Thanks,
Dan
Thanks,
Dan
Hey Fundem, those issues sound crazy! Are you still having problems?
My only suggestions would be to either disconnect your battery for more than 10 minutes or to reinstall you wires. It's possible one of the wires may be disconnected or another electrical component has been disconnected in the engine bay.
Did you install these yourself or get a shop to put em in?
I remember I drove my sister's SUV home from the dealership after an oil change and about 1 mile down the road the ***** started smoking like crazy under the hood! Turned around and drove it back to the dealer. Turns out they forgot to tighten the oil cap. Those snaky punks....
By the way, I still haven't received my shipment from Racingline. UPS from Canada takes forever! Any day now....
Had them installed on my engine for a couple weeks now. Don't really notice any major changes.
The audio is more crisp and bass hits harder at level 10 than before. My headlights are a tad bit brighter. Windows aren't any faster.
Faster auto shifts.... Dunno.
Better MPG..... About the same.
Increase in HP... Minuscule if any.
But I do feel good that I have better grounding. Haha! This mod is okay at best.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
REDinLV
10-18-2015 05:31 AM
Pied
09-26-2015 03:29 PM
