Sponsored by:
Sponsored by:
Noise while pushing brake (door lock sound)
Old 09-17-2016, 12:21 AM
Reza2016's Avatar
I tried to start my Maxima 2013 engine on that all the electric went out. After seconds the light (on odometer) was on so I tried one more time to start the engine but it was about to start the engine that the same problem happened. I tried several times but no success. Then I played with the connections of the battery and it seemed one of them was loosed. Finally I could start the car but I noticed when the car is in park mode and I press the brake pedal it make a click noise from the gear **** area located under the center console (is similar to the relay sound). The interesting point is that the noise is not heard when the car shift into drive or reverse. I remove my foot from brake and press the accelerator pedal. After the car started to move, I pressed the brake but the noise was not heard. I did almost the same test, pressed the hand brake and shifted into the drive and pushed the brake but no noise was heard. I am wondering if the click sound in park mode while pressing brake pedal is a problem?
Reza2016 is offline
Old 09-17-2016, 05:56 AM
14blackbeauty's Avatar
most likely an interlock which allows you to start the car,
14blackbeauty is offline
mfshehri
07-21-2016 03:25 PM
Icecold
07-11-2016 06:41 AM
chevyman1980
07-06-2016 06:54 PM
Jomil
06-22-2016 09:35 AM
Quick Reply: Noise while pushing brake (door lock sound)
