Go Back   Maxima Forums > Maxima Discussions > 7th Generation Maxima (2009-)
7th Generation Maxima (2009-) Come in and talk about the newly redesigned 7th generation Maxima
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-06-2009, 09:44 PM   #1
Send a message via AIM to KillaKam
Rear Sway Bar Question?
Ok so I have a Stillen RSB on my car at the moment but I never got into thinking if adding something stiffer to the car would cause any issues with the suspension components such as the endlinks or other issues? Can anyone help me on this? I just want to make sure that adding a stiffer part to the car wont cause me to either lose control of my car, wear parts down quicker, and or snap parts or something like that.
If so what options can I take to avoid this?
Thanx all...
__________________
2009 Radiant Silver Nissan Maxima SV-S
Mod's: 20% Tints F&B, Stillen Cold-Air Hi- Flow Intake, Stillen CatBack Exhaust System, Stillen Rear Sway Bar, Stillen Grounding Kit (RED), Racingline Performance FSTB
KillaKam is offline   Reply With Quote
Old 10-06-2009, 10:06 PM   #2
Thanx all...
I couldn't help but notice that you mentioned in some other post that you have heard of an adjustable sway bar that will be coming out. From who? Perhaps a stupid question, but what about the front? why are there no 'kits' for both front and rear? i.e. Eibach pro kit? something like that? I got the lowering springs and let me tell ya, they helped A TON. I'm wondering if it's worth exploring the other elements of suspension yet or if I should wait out the storm?
ANNINO is offline   Reply With Quote
Old 10-06-2009, 10:13 PM   #3
Thanx all...
In response to your question, end links seem interesting. They pre-tension the sway bars, which leads to increased stress on the parts under load. While this would result in stiffer handling, in theory, without knowing the exact material of the sway bars, bolts holding down the bushings or end-links, etc., there is no way for us to 'predict' if the application is 'safe' or not. I guess you have to put faith in the manufacturer. Racingline, please chime in and enlighten us...
Old 10-07-2009, 10:36 AM   #4
Send a message via MSN to Mreim769
Quote:
I can agree with that assessment. However, knowing the way that Kam shops around I highly doubt he bought a plastic sway bar so I am sure it is safe in that regards. My answer to the original question would be that adding strut braces should not compromise any of the other suspension components, major abuse aside of course. Also, upgrading to aftermarket end links with our suspension setup should have little effect unless you are eventually track prepping your car in which case more upgrades besides end links would be required.
__________________
MaTt
Mreim769 is offline   Reply With Quote
Old 10-07-2009, 11:17 AM   #5
Well both of you are correct in ways.. I am useing Stillen RSB and I have faith in it very much. It is stiffer than the stock and You can tell. The worry that I am having is if by adding a different RSB that is stiffer lets say up to 40% on the lowest setting and almost 100% compared to Stillens eventually in certain situations there are issues that could occur such as oversteer, snapping the endlinks, or other issues with the suspension. To my knowledge these factors become greater when you lower the car as you are not putting even more pressure on those parts that weren't built for the parts your putting on.
__________________
Old 10-07-2009, 02:21 PM   #6
Do you plan on taking your Max to the track?
__________________
MaTt
Old 10-07-2009, 07:37 PM   #7
Quote:
Probably one but not soon just for straight anyways thats about it.
__________________
Old 10-07-2009, 09:54 PM   #8
What about strut towers can they harm any other components in the front suspension?
Maxima2009 is offline   Reply With Quote
Old 10-08-2009, 04:44 AM   #9
I will not be responsible for any damage to your vehicle, but I will say no, they are practically risk free. The max already has a strut tower of sorts, little 'winglets' that connect the struts to the firewall at an angle. By adding a FSTB you are completing the triangle and creating an extremely rigid structure, much more so than if you just added a FSTB on a 'regular' car.
Old 10-12-2009, 07:03 PM   #10
If not taking the car to track... Don't add the STB... You'll regret the roughness. Before moving to the Max, I had my Altima coupe tricked out with Eibach, RacingLine end links, RSB, and STB... It was WAYYYY too rough and it's the fear (from sound and tire noise) that's going to be prohibiting you to make use of it on streets. If it's a smoothe, clean track, I'd say go all out. The Max is a very powerful sport-y commuter car, nothing more. I love it to death but I doubt more than 5% will track it enough to warrant RSB, STB, and end links. Eibach's I can understand because they make the car look sooo much better and the lower center of gravity is okay.
BUT it IS your car so whatever so don't heed my opinon :P
michaelthepsycho is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
