All wheels have a center hole for the axle and a bolt circle containing holes through which the mounting studs pass through. Aftermarket wheels must have the same bolt circle. The center hole, however can be larger than the car's axle mount (hub). Mounting such wheels cause the wheels to be "lug centric" since the center hole cannot be mated to the axle mounting surface. Lug centric is not desired. To correct this, an adaptor is made that fits over the axle mount (press fit) that allows the aftermarket wheel to be on the axle mount. This is "hub centric" and ensures that the wheel's rotational axis is coincident with the axis of the car's axle.
As far as I know, the adaptor is always available from the aftermarket wheel manufacturer.
__________________
2009 Navy Blue Maxima SV + Premium Pkg.
