Go Back   Maxima Forums > Maxima Discussions > 7th Generation Maxima (2009-)
7th Generation Maxima (2009-) Come in and talk about the newly redesigned 7th generation Maxima
Thread Tools Display Modes
Old 08-30-2008, 06:10 PM   #1
Send a message via AIM to rkurlander
2009 Maxima problem
I have a problem on new 2009 Maxima with 700 miles. "Check engine light soon" light came on five days ago. Gas cap was on tight with 'three clicks'. Took it to dealer. They found nothing wrong and re-set everything. Today the light is on again. Obviously I can't contact dealer until Tuesday morning due to Labor Day. Any thoughts?
rkurlander is offline   Reply With Quote
Old 08-30-2008, 06:13 PM   #2
these cars are built crappy. another reason i quit the plant. i love maxima's just as much as the next person. but since the 6th gen theve been going down hill
__________________
THE MAX
tigersharkdude is offline   Reply With Quote
Old 08-30-2008, 07:15 PM   #3
Send a message via MSN to burhan92SE
probably it wants u to tuneup or change some fluid in the car?
burhan92SE is offline   Reply With Quote
Old 08-30-2008, 07:50 PM   #4
Z
NYPD-Arnold's Avatar
Go to AutoZone and have the code read for free.
__________________
2006 Daytona/Frost 5AT: MotorDyne 5/16 Plenum Spacer | BTDC@17 | Borla True Dual | Ultimate Racing HFCs | Jim Wolf Popcharger | Weight: 3175lbs - 60LBS Weight Red. | Hotchkis Springs | Eibach 15mm Rear Spacers |Michelin Pilot Sports | Dunlop M3s | 3M Clear Bra | Polished Mini Antenna | 2005 FX35 Graphite/Brick
NYPD-Arnold is offline   Reply With Quote
Old 08-30-2008, 07:51 PM   #5
I feel your dealer has let you down. Instead of determining why the light came on, they simply reset it, which is Like jumping into the river a second time, thinking you will not get wet like you did the first time. Dealership service departments are a car manufacturer's worst nightmare.
lightonthehill is online now   Reply With Quote
Old 08-30-2008, 07:55 PM   #6
I agree, go to auto zone.
drakutis is offline   Reply With Quote
Old 08-30-2008, 08:00 PM   #7
Quote:
I beg to differ. I'm sure some folks have some problems with Maximas; ALL makes of cars give SOME trouble. But I love my 6th gen, and have had nothing done other than scheduled service for the last three years and ten months. When I see the frustrating problems my relatives, friends and neighbors always seem to be having with other cars, I thank my lucky stars I buy only Maximas.
VIVA LA MAXIMA!
Old 08-30-2008, 08:09 PM   #8
this happened to me, dealer didnt close the gas cap enough, you say 3 clicks, i say 5 clicks. they checked mine, then reset it though. they should have hooked your max to the diagnostic computer. anyways try closing with 5 clicks then drive anround should go away in a couple days. do a freeway drive too
__________________
slater is offline   Reply With Quote
Old 08-30-2008, 08:13 PM   #9
wow, a code already!
hopefully something easy to fix...
__________________
SHIFT_Quickly or You Lose
03 6spd Sunlit Sand Maxima---JWT | HH | SSIM | NWP Spacers | Moto UDP | 17 BTDC | Ground kit | VAFCII tuned | STS | FSTB | RSB | 249whp/242tq
97 NOS Concord Mist Maxima--Sold
93 White Maxima--Sold
MaximusMorpheus is offline   Reply With Quote
Old 08-31-2008, 07:02 AM   #10
reb
"Dealership service departments are a car manufacturer's worst nightmare"
I agree and then some. However, I've found Nissan service dept.'s to be amoung the worst of all...........
reb is offline   Reply With Quote
Old 08-31-2008, 07:04 AM   #11
reb
I thought that some of the '09 Maxes were being built in Japan.
Old 08-31-2008, 08:23 AM   #12
Seems like something small to overreact to, not something I would be concerned with, Nissan and all the others have their cars setup to throw a SES light if the gas cap is loose or the engine is gonna blow, seems extreme but for this exact reason they make you want to believe your car is self destructing when it's probably something as small as bad gas
__________________
2006 SE Maxima, Onyx
OEM All-Weather Mats
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
RTP Cross drilled/Slotted, F&R
Hawk HPS pads
AT Grounding Kit
STARR is offline   Reply With Quote
Old 08-31-2008, 08:28 AM   #13
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
Just make a quick trip to Autozone, get the code, and fix it. Isn't that hard and I doubt its anything major so don't worry.
ChrisMan287 is offline   Reply With Quote
Old 08-31-2008, 08:35 AM   #14
Sometimes the light will illuminate if you fill your gas tank beyond the AUTOMATIC trigger when the pump stops...DO NOT OVERFILL your tank. My friend experienced this on his Honda Accord...he said to share this with you. I hope this helps.
SirLennox is offline   Reply With Quote
Old 08-31-2008, 08:44 AM   #15
Quote:
i am pretty darn sure they are all built about 1 mile from where i am typing this message from, Smyrna, TN
Minarets is offline   Reply With Quote
Old 08-31-2008, 01:42 PM   #16
Quote:
Correct. Not one Maxima has been built outside Smyrna TN since the last 2003 Maxima rolled off the assembly line.
Old 08-31-2008, 01:46 PM   #17
Send a message via AIM to Yaco_Max
Nissan. Made In USA.
Infiniti. Made in Japan.
__________________
Waiting for the Maxima 3.7 SV with Premium Package.....2010 or sooner?
Yaco_Max is offline   Reply With Quote
Old 08-31-2008, 02:52 PM   #18
Not entirely true. The Nissan Murano and Rogue are both made in Kyūshū, Japan while the Infiniti QX56 is made in Canton, Mississippi
BobXX is offline   Reply With Quote
Old 08-31-2008, 04:36 PM   #19
Quote:
i do believe you are wrong sir. Nissan has 3 plants in the south and i do believe the one Mississippi makes them as well. i do believe i am correct. if i am wrong someone speak up
__________________
THE MAX
Old 08-31-2008, 05:04 PM   #20
Quote:
For the 2008 model year the QX56 was moved to Japan to try and eliminate some problems, and also add to the luxury/prestige and premium price by having it built in Japan.
I'll have to agree with tigersharkdude, the 6th gens at one time where made in Missouri or Mississippi plant but due to quality control where moved to TN, the vin number should say which plant it is made in
__________________
15% TINT
FUJITA CAI
Stillen FSTB
Nismo Sway Bars
Yokohama Avid W4s
Hawk HPS pads
AT Grounding Kit
Old 08-31-2008, 05:20 PM   #21
i believe the 7th gen is as well, or will be soon
__________________
THE MAX
Old 08-31-2008, 05:42 PM   #22
Quote:
QX56 and Quest production is being moved to Japan for the 2009 model year.
Old 08-31-2008, 07:06 PM   #23
all maximas and altimas come out of symrna tenn, no where else
__________________
Old 08-31-2008, 07:29 PM   #24
how do u know this. because at work we had production numbers. and told us how many alt's we were to built, and how many canton was supposed to build
__________________
THE MAX
Old 08-31-2008, 09:22 PM   #25
You're correct, but most of the Infiniti models were move to Japan to try and eliminate some problems.
__________________
Old 08-31-2008, 09:50 PM   #26
canton is trucks and minivans, armada and titans and quests
__________________
Old 08-31-2008, 11:10 PM   #27
Error Codes
Is there a way you can push a few buttons on the dash and get the Display to go into Diagnostic Display Mode where you can scroll thru the codes and Reset them if you want?
If so a post on How-To & Code Values would really be great.
__________________
09Max
09Max is offline   Reply With Quote
Old 09-01-2008, 01:19 AM   #28
I only repeat what Nissan has said over the last five years, and told me again this year. While touring the Nissan assembly plant in Smyrna back in April, we were told that ALL Maximas were assembled in Smyrna, and had been since Maxima production began in the U.S. in January, 2003 with the first 2004s.
I have relatives in the Canton-Jackson Mississippi area, and they have told me several times they wish Nissan would make some of the Maximas in their plant, but they never have.
We have even one more way of knowing all Maximas are assembled in Smyrna: The VIN character immediately in front of the serial (which uses the last six positions of the VIN) is the ASSEMBLY PLANT ID. Nissan has around a dozen assembly plants worldwide, and uses a 'C' is this position to denote the Smyrna plant. All 6th and 7th gen Maximas I have checked have had a 'C' in this position. One can check the inventory of every Nissan dealer in the country on nissanusa, and the VINs of all Maximas I have looked at there also have a 'C' in that position.
This makes sense, as the Maxima is not a high-volume vehicle. It would be inefficient to go to the great expense of having more than one assembly line set up to build a vehicle intended to sell only around 70K copies.
