AC fluid or radiator fluid?
Old 04-27-2024, 09:13 AM
ffo_kcuf_i's Avatar
I hit an 18 wheeler tire on the Interstate yesterday. Destroyed the front bumper, bent the ac condenser and broke the lower drive side of the radiator support. I have a light green fluid leaking slowly and I first thought it was from the radiator due to the color, but it appears as though it may be coming from the condenser.
I thought freon was colorless.
ffo_kcuf_i is offline
Old 04-27-2024, 09:43 AM
Richard66's Avatar
I would say that is radiator coolant if its the same color as in the radiator. Freon or other fluids used in air conditioning turns to a gas at room temperature, so if that leaked out as a liquid it would quickly turn to a gas.
Richard66 is online now
Old 04-27-2024, 01:07 PM
ffo_kcuf_i's Avatar
I checked and the radiator coolant is blue. I'm assuming this is a dye in the ac refrigerant. I didn't know this was a thing, but doing more research, it seems that's what it is
Old 04-27-2024, 03:00 PM
Maxgig's Avatar
I'm pretty certain that's radiator coolant. You more than likely have the green stuff in the lower part of the radiator and when it got smashed it leaked out. A/C freon will come out as a gas and will be extremely cold and will turn what it touches white with frost.
Maxgig is offline
Old 04-27-2024, 04:14 PM
LtLeary's Avatar
Check your cvt fluid level. Our 7th gens have a cvt cooloer on the radiator and lines go from it to the filtee by the drivers side wheel.
Cvt fluid is light green.
LtLeary is offline
Old 04-27-2024, 05:48 PM
Maxgig's Avatar
I totally forgot, some CVT fluids are green. My last 2 fluid changes it was oil colored. But for certain we know it's not freon.
Maxgig is offline
RITE
08-15-2023 11:15 AM
Eric Fowler
04-19-2021 03:43 PM
dansmax2003
01-08-2009 01:09 PM
raeqwon28
09-11-2002 11:14 AM
NickStam
08-26-2001 09:07 AM
Quick Reply: AC fluid or radiator fluid?
