Window Grinding Noise
Old 06-08-2020, 11:24 AM
tbm5690's Avatar
My driver's door window has a bit of a grind to it that I've put off addressing for a couple of years now...raising or lowering works fine, no perceived "slowing" in speed, just sounds like there are rocks in the track when it is in motion. Thoughts on whether or not this is a regulator issue or a motor issue?
tbm5690 is offline
Old 06-08-2020, 09:19 PM
Bificus99's Avatar
Mine can make some nasty sounds too from time to time. Especially if my car is in serious need of a wash.
Bificus99 is offline
Old 06-09-2020, 12:51 PM
tbm5690's Avatar
Mine's definitely not dirt-related, noise happens internally regardless of how clean the window is.
tbm5690 is offline
Old 06-10-2020, 05:09 AM
maxipower's Avatar
i used wd 40 on both sides of the window track while window is down and repeat once so often . it helps making the window rising and lowering with lesser grinding,,try it ,,got nothing to lose
maxipower is offline
Old 06-11-2020, 06:01 PM
tbm5690's Avatar
I used a silicone lubricant, didn't make any noticeable difference.
tbm5690 is offline
King_Ten_Ahead
01-04-2014 12:19 PM
cmd26
01-26-2011 08:56 AM
ROCKART
12-06-2009 11:23 AM
Bborges
01-19-2006 10:25 AM
joe4
12-25-2004 08:57 PM
Quick Reply: Window Grinding Noise
