Has anyone cleaned their throttle body?
I am wondering if some of my smoothness issues might be a dirty throttle body and I was thinking of giving it a cleaning but I sure don't want to mess anything up. I cleaned the throttle body on a 2007 Mustang one time that had horrible build up and after I put everything back together the car was idling at like 3,000 rpm...I had to unplug the battery for 10 minutes for the computer to reset, but man after I did it was butter smooth. I don't know how the VQ takes to a TB cleaning though.
Yes.. cleaning the Tb will help smooth out idle issues.... Very simple.. Do NOT use Brake clean or the like.. Use only Tb cleaner.. Gently open the blade by hand and spray some on a micro fiber and clean the varnish off..Do not use a brush .. it is imperative you do not remove the coating inside the TB... Gently wipe away the deposits and you are set.
Y
A common word in 5.5th gen Maximas was to NEVER move or open plate manually, someone is needed to push the accelerator and you wipe while it's open. Can not see how this is different in the 7th gen. OR you remove the TB from car and clean it outside (you'll need a gasket to put it back on manifold).
Just don't move that flap at all when you're cleaning the throttle body. I find it best using WD-40 first with a brush to get all the hard gunk out. Then use Carb spray as a final touch up. Doing it this way got both sides of the flap cleaned very well without having to move it and risk any calibration offset.
"Ebay" doesn't produce or sell anything. It is an online auction platform. The seller of this throttle body, "thepartmonster", has been in business almost ten years, has a feedback count of over one hundred thirteen thousand and a rating of 99.2%. With Ebay policy and consumer protection behind every transaction, there would be absolutely zero hesitation by me to purchase this item, and in fact, I have. I have been an ebay seller and buyer since they launched. Savvy consumers whom abide by the caveat emptor principle rarely, if ever have issues using ebay. People who bash ebay always have some weird, drama-filled story behind their negative experience and are the type to write negative amazon reviews on a cat condo that fell apart because they don't know the difference between a phillips and a flat head and their 5lb kitten toppled it in a week. Meanwhile, I ignore negative reviews from retards, purchase anyway and build the same condo, do a proper job as well as anchor it to a wall and my fatass 25lb cat who thinks he's spiderman has been tearing up and down the thing for a year and it still stands.
How do you know if the throttle body is your problem? From the sound of your posts you are just guessing. Before opening that up and more than likely causing more problems try running a bottle of BK44 through a tank of high octane top tier gasoline.
YES, I just had a BG treatment for my 2011 SV @ 115K miles, The treatment cleans the throttle body and all of the interior manifold. These 3.5 engines revert 40% - 50%of the spent
cylinder exhaust back into the combustion chambers. The indirect fuel injectors automatically clean the valves however, the manifold gets a lot of carbon deposit. My mechanic advised me that newer Fords and Chevy's highly recommend an intake manifold cleaning after 60K. I noticed a big difference in power after the treatment.
After 150,000 miles on the plugs and 375,000 on the engine.
