Can't open drivers door from inside or outside car?!
Is it cold out and have you taken it through a car wash lately?
Mine freezes up all the time.
The electic activator gets water in it.
Now I use WD40 prior to and after every winter wash.
I soak the lock set, door handle area and door latch area.
I had mine washed today and it will be -15 C tonight.
Here's hoping the WD does the trick or I'll be climbing over the console again.
Hard to tell. You could try and disconnect the neg batt term for a few minutes and reinstall then check the door.
The BCM in these cars does some weird chit!
I have had on-again off-again problems with the functionality of both left side doors in my car. In fact the left pass door lock finally decided to start working again today?
This is a total PITA because I'll start to think it's locking ok and if I'm not vigilant it will remain unlocked while the 3 other doors lock....so I have to pull on it each time I leave the car to verify it's locked or unlocked.
I had it in a garage for several hours and no luck. I took it to 4 body shops and none of them could get the door open, they said the latch is locked and they can't get it open. I have no choice but to take it to the dealer. Not sure what they can to get it open or If there's a way to get the door panel off with the door closed. We will see. Hopefully it doesn't cost an arm and a leg..
Same happened to me,my window tint guy was able to open the door without removing the panel and wd40 the ish outta the actuator and get it working again,that was a year ago and only charged me 30 bucks and told me to keep aplying it at leats once a month on all doors as a preventive measure...hope this helps
The gentleman at the audio shop was able to get the door open without breaking the panel. I'm definitely impressed considering 4 auto body shops said there was no way and the dealer said the same thing. A job that was quoted at $1050 from the dealer will now cost about $400.
How did you open your door? The same thing happened to me and I am trying to figure out what to do to fix it except for me it's the passenger side front door. A couple places said it would be around $50 for them to take the panel off to figure out what's wrong with it but I forgot to ask them if they know that there's no way to open the door for them to be able to take the panel off.
Lakersallday24
06-16-2019 01:35 AM
King_Ten_Ahead
09-30-2015 04:27 PM
MAXSE5SPD
08-23-2015 12:06 PM
MaximaDrvr
08-19-2015 08:20 PM
erniel
08-08-2015 09:32 AM
