2013 maxima after market double din radio install help
Old 12-19-2014, 03:22 PM
Brian97's Avatar
Help please!!!! I installed a double din radio in my 2013 maxima last night and everything works great except the heat and air controls what am I missing does the controls run through the factory radio or what help me please????
Brian97 is offline
Old 12-19-2014, 03:28 PM
koreanthunda's Avatar
What plug or adapter did you use ?
koreanthunda is offline
Old 12-19-2014, 03:32 PM
Brian97's Avatar
Nwh704 harness said its for 2007 to 2013 nissan
Brian97 is offline
Old 12-19-2014, 03:34 PM
Double check the year for the car maybe you have the wrong ones and double check your connections . Send me a picture
Old 12-19-2014, 03:46 PM
Brian97's Avatar
Brian97 is offline
Old 12-19-2014, 04:20 PM
Is that to the wiring harness ??
Or the car ?
Old 12-19-2014, 04:54 PM
Brian97's Avatar
This is the end of the aftermarket harness that goes to the car side
Brian97 is offline
Old 12-19-2014, 04:56 PM
Brian97's Avatar
I think I need a harness with more plug ins to make ac and heat unit work but there is nothing on the web
Brian97 is offline
Old 12-19-2014, 04:59 PM
Brian97's Avatar
I just can't believe nobody has never put a radio in a 2013 max or let's say there is no info to be found
Brian97 is offline
Old 12-20-2014, 04:33 AM
Tommy6905's Avatar
Are your hvac controls up top or part of the radio down below? And did u reinstall the climate control box back
Tommy6905 is offline
Old 12-20-2014, 05:32 AM
Brian97's Avatar
My controls are on top and yes I hooked everything back up here is what I tried I put the old radio in and everything works I started unplugging harness out of the back of the factory radio until I found the one that controls the ac controls but the problem is when I install my pioneer radio that harness is not used there s 2 unused plugs in the cars factory wiring harness that don't get used so I am thinking I need a wiring diagram to see if maybe the ac controls are just getting asses power from old radio that's the part I don't know
Brian97 is offline
Old 12-21-2014, 07:22 AM
Your missing a plug somewhere . Take pics of the dash
cheftoo
08-20-2015 05:17 AM
Samedi
08-13-2015 04:05 PM
MikesChevelle
08-10-2015 11:21 AM
altmycar
08-06-2015 04:44 PM
Quick Reply: 2013 maxima after market double din radio install help
