Heated steering wheel switch-remain "on" when car is shut off?
I would like to change the button for my heated steering wheel to a toggle type switch (like the heated seats) OR figure out how to have it remain "on" when I shut of the car-by this I don't mean it heats the wheel while the car is off, but rather it turns right back on when the car is turned on, like the heated seats.
I am installing a remote start system and I would like to be able to leave the heated steering wheel on when I get out of my car, so that when I remote start, it will come on when the car starts and be nice and toasty by the time I get in.
Does anyone have any thoughts on this? Is there a way I can make this happen WITHOUT changing the switch. I'd like to do this while I have all the dash pieces off for installing the remote start.
I have nothing to add, but I do have a question: Why?
Why go through the hassle and expense (and possible voiding of warranty/expensive repair if you mess up) so you don't have to push a conveniently located button for part of a year? Seems like a waste of effort, time and money. But I'm curious as to why.
I believe ever car with heated steering wheels requires that it be turned on each time it is to be used.
The main reason I ask is because mods bring resale values down, which is why most folks return their vehicle to stock prior to selling.
As always, do whatever you want to your car. I'm just curious why you want to go through all that hassle.
So a few hours of research and wiring and the possibility of damaging the system or car to save 10 seconds? I just want to make sure I understand.
It is a latched switch relay.
When you press the button, it "latches" till you press it again, or it looses power.
You could replace the latch switch with a relay that is always energized when the car is on, and a separate switch to operate the on/off function.
I checked the switch on the way home tonight. You cannot just wire a switch in there, turn it on and leave it on. The circuit requires that the switch be closed/depressed after the vehicle is started.
Try pressing and holding the switch and then start the vehicle. The heated steering wheel will not turn on until you let go of the switch and press it again. The circuit is designed that way for a reason.
You could install a timed switch or relay to perform this function but it is really not worth it. This is one mod that is probably best not performed.
I live in Chicago too--- it's not Siberia though it felt like it last winter. Not that hard to flip the steering wheel heater on when you need it. Mine heats up pretty quick and gets quite toasty--- sometimes I even have to turn it off because it starts to get too warm. Not a big enough benefit to warrant taking the chance of messing something up...
Mine begins to heat mere seconds after I push the switch. I usually have to turn it off within a minute or two because the wheel gets uncomfortably hot.
Even though, once on, the switch light stays on until we either turn it off or turn the car off, the heat is not applied constantly. A thermostat turns the heat off and on in order to avoid dangerous overheating. If the ambient heat inside the car is over 70 degrees, the wheel heater temperature detector usually blocks the wheel heater.
I also find the wheel heats up VERY fast. It's none of my business what the OP wants to do to the car, but please consider that if any changes to the wiring cause a problem....and God forbit your car burns to the ground...I'd be asking myself why I bothered.
Having said my peace, I fully accept that any owner can modify their car to suit their wishes, except if those mods place others in danger. No adding oil slick, marble discharge chute or extendable axle tire schredders please! Ejection seats are usually okay by me, as I have them in all my rides.
I absolutely understand what the OP is wanting to do and why he wants to do it. I thought of the same thing for myself because I remote start and the car is warm but steering wheel is freezing. The steering wheel does heat up but definitely not in 10 seconds.I can feel it getting warmer quickly but it usually takes 2-4 minutes before its where I want it to be and when you have freezing hands, sooner is better than later. This MOD is not something I personally would try reading the above posts. Too much work for not that huge of a deal.
Thank you, that's what I was looking for. I will do some investigating, and see if I can make this work.
Keep us posted on if you can or what you decide to try. I must admit though, mine warms up literally within 20 seconds and is hot within 40 seconds. I do understand though, i used to live in Ohio where it reached 20 below, but now being in vegas, huge difference. So taking that into account, i can see it taking a few mins for you east coasters to get it to warm. Once again, good luck. :-D.
trasmadean
02-01-2017 08:20 PM
MikesChevelle
08-06-2015 11:36 AM
