where do the side vents (next to the fog lights) go?
Should have taken a closer look when I installed the fog light's and had the engine pan off.
Just wondering where all the air goes that these little gems scoop up?
There are slots in the fender well plastics. I assume it's designed to keep the brakes cool. There's a lot of people here with 09-10s including myself still running the factory brakes with lots of life left. I'm just throwing it out there but maybe it prolongs the life the of brakes as well
They are vented through the wheel well covers to run air through the wheel housing to cool rotors and pads. Both sides should have them. Also used to force air through and around the car for aerodynamics as well. Hope that clears it up.
http://mustangforums.com/forum/s197-...brication.html
I just need to find someone good at fabricating/welding for the brake shield.
http://www.edmunds.com/nissan/maxima/2009/road-test-specs.html
I'm not trying to stir anything up here, just curious why it's advertised if there's no function or is there a difference between a ventilated disc and the function of these brake ducts?
Ventilated discs means double thickness, with vanes in the middle, vs solid discs (usually on the rear).
http://maxbrakes.com/files/images/su...lid_vented.png
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
98nismomax
08-13-2015 12:44 PM
