Removing Engine Cover
I must be missing something totally obvious but I am having trouble removing the engine cover. I read the owner’s manual that states to “pull cover up first and then toward the front of the car”. I removed the two bolts at the top using an allen wrench and tried pulling up and forward but it looks like there are two bolts on the bottom that are holding it in. Is there a way of removing the cover without removing those two bottom bolts? If I do have to remove the bolts how do I access them?
I'm sure you can, just make sure you adjust the screw driver carefully as not to break/crack the plastic.
The Frye
09-02-2021 11:03 AM
lowpost99
09-08-2015 05:06 AM
03VQMAX
09-05-2015 03:47 PM
