Question bout vibration
Old 01-11-2014, 04:37 AM
Maxnissan's Avatar
I have 10 maxima. I have a slight vibration in the driver side around the tire area. It is noticeable around 40 mph n slightly more at 80. It feels as it comes n goes like a pattern but is continuous. I'm thinking its the axle or wheel bearing. I've ruled out the fluid in the cvt, tires, and brakes. Any help is appreciated.
Maxnissan is offline
Old 01-11-2014, 11:38 AM
ac max 92's Avatar
Start by checking that your lug nuts are torqed otherwise yes it does sound like it could be a wheel bearing or if you had the tires changed and possibly not balanced properly?
ac max 92 is offline
Old 01-11-2014, 12:10 PM
04BlackMaxx's Avatar
are you bout it bout it
04BlackMaxx is offline
Old 01-11-2014, 01:18 PM
Maxnissan's Avatar
Vibration
Not tires. Is the wheel bearing hard to replace? Is it pressed in?
Old 01-11-2014, 05:19 PM
ac max 92's Avatar
From what i see it's one assembly for your hub and bearing no need to press em. You should check with your dealership first to see if it's still covered under your powertrain warranty.
Old 01-12-2014, 11:08 AM
i8acobra's Avatar
Visit the dealer. Bearings are 5/60. That's probably not it though.
i8acobra is offline
Old 01-15-2014, 06:04 PM
Jim Leahy's Avatar
My front drivers side bearing was shot. 100 for a Timken Bearing on line and about 1.5 hours. Impact wrench and a wobble extension socket make it a dream.
Jim Leahy is offline
Old 01-15-2014, 06:39 PM
13Maximasv's Avatar
bent wheel ? Very hard to see inside bends with the car on the ground
13Maximasv is offline
Old 01-16-2014, 05:41 AM
vball_max's Avatar
How do you know its not the tires? Probably 90% of vibration problems are wheel balance or out of round tires.
Bad bearings typically make a humming sound, not vibrations from what I've heard.
Bent wheel is definitely a possibility too. Lift the front end and give the wheels a spin. Look at the inside of the rim really carefully while you or someone else spins them.
vball_max is offline
Old 01-16-2014, 06:04 PM
Maxnissan's Avatar
The rims and tires have been changed. It is a humming but you can feel the vibration in the floor. I bet most people wouldn't notice. The comes n goes like cars passing by on a race track. Thanks for help.
Old 01-17-2014, 02:23 PM
Jim Leahy's Avatar
you could just hear the growl, couldn't really feel it, just could hear it.
When I took the bearing off it was rough to roll. Obviously bad, big question is do I do the other side?
hcarter1112
42
07-18-2022 03:35 PM
Unclejunebug
04-02-2016 05:42 AM
coolsun
Wheels/Tires
10-15-2015 10:52 PM
Stagnet04
10-11-2015 08:16 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Question bout vibration
