View Poll Results: Your Satisfaction with 7th Gen Heated and/or Cooled Seats - Select all that apply
Both of my seats heat adequately but other vehicles I have owned or been in worked much better.
33.33%
One or both of my seats do not heat well or evenly appears to be something wrong. I'm disappointed.
41.67%
My climate controlled drivers seat cools well even on the hottest days. I'm totally satisfied.
11.11%
Multiple Choice Poll. Voters: 36. You may not vote on this poll
Poll: Do your 7th Gen Heated/Cooled Seats work to your satisfaction?
Since some of us have had issues with our 7th gen heated and/or cooled seats I thought it would be useful if others shared their thoughts regarding the seats by participating in a poll. This is a multiple choice poll select answers all that apply.
Your input and comments are appreciated.
I've got a '10 SV Prem/Tech and the heated seats and heated steering work great (as long as I keep the temperature closer to 90) but the ventilated seats could definitely use some redesign...
my seats
I find that both seats and the steering wheel in my 14' SV heats up quite nicely. I have no complaints! I haven't tried the cooled feature yet, but if its anything like my old M35 or my BMW 750, I would imagine it would cool best with the AC on.
Does the drivers side seat back and seat bottom heat evenly and do they both get very warm quickly if set on high? Does your passenger side heat strongly if set on high?
My drivers seat bottom does not seem to heat at all and the passenger side heats weakly even on high. The dealer checked the seats and said they test normal according to Nissan specs. He also stated that other Maxima's on his lot heat in a manner similar to mine. So we are kind of stumped at this point.
Don't know if theres some sort of sensor in the seat that possibly adjusts the temp accordingly, but thats just what I've noticed.
None, my wife usually has to turn it off because its too hot. What setting do you have your climate set too? Have you tried setting the temp to 90 and either vents & floor or single w/ ac button off? Thats my usual settings.
Why would anyone drive around with the temp set to 90. That would heat the cabin, the seats and me. The cabin heat setting has nothing to do with the seats.
The steering wheel turns off after a certain time, I think cause some areas get too hot. I try to move my hands around the wheel otherwise certain spots get ridiculously hot.
Heated seats work great in my experience, love them.
My '09 is 5 years and 4 months old, and I have had no problems with my heated and cooled seats so far. My wife and I are almost always in the car together, and we take turns driving, so we each get to use both seats. Everything has worked fine so far.
The heated seats are most effective when we are not wearing jackets that tend to insulate us from the heated seat.
Being a child of the depression, my gnarly old hands have no circulation, so the heated steering wheel is not a luxury, but an absolute requirement for me. I would never consider buying a car without a heated steering wheel. However I would probably have designed the heat controls on the steering wheel a little differently.
The wheel heats up very quickly, but on cold mornings, sometimes gets hot enough to burn our hands. Then, once the temperature reaches 70 inside the cabin, the heater on the steering wheel goes into an 'on-off' cycle that is a little less than ideal. But not bad enough to bother complaining about.
so anyone have a 2010 in here? When you turn on your seats does it get so hot so you switch to LOW? ... mine never get so got like my girls Altima or our Pathfinder... they heat up but no too much... should i go get it checked?
I just have regular heated seats. Well my situation is that when i turn on my seats on HIGH it never gets so hot for me to turn it to LOW. I had Altima n now i have 2013 Pathfinder... seats get so hot it almost burn my *** off lol I need to turn it down after 20 min it gets so hot... in my Maxima seats are on HIGH all the time and not even close in temperature comaring to my other vehicles... I just bought it tho that's why I'm wondering if everything works fine or maybe i need to replace heating pads...
Why would Nissan use a seat in one of their vehicles that almost burns you and then use a seat in a Maxima that does not heat adequately.
They will then tell you that the Maxima seat only heats a bit because of the airbags or some other BS reason. Does that reason not apply to the Pathfinder and Altima also?
When I last went for service the dealer was adamant that I could not check out other Maxima's heated seat operation. Were they afraid I may find one that work fine?
Both of my heated seats work great. Haven't had a chance to fully experience my cooled driver seat to its full potential yet, but I did turn it on for a second by mistake with the heat on 80. Was wondering why I felt so damn cold then looked down but it was only turned one notch..
Why make a heated seat that does not heat adequately, what is the point. What if I sold you an iron that did not get very warm. Would you be satisfied with that. You would probably take it back demand a working iron that gets hot or your ask for your money back. The same should hold true for your heated seats.
If the seats were like this since new I would still contact the Dealer and Nissan Consumer Affairs ask why you were sold a vehicle with seats that provide inadequate heat. Use the example of the iron to prove your point.
There are companies out there that make aftermarket seat heaters that you can install yourself or you could have someone install them for you. They are not very expensive and I can almost guarantee you that these will provide more than adequate heat. These aftermarket companies realize that if they sell a product that does not function as the consumer expects they will not be in business for very long.
These guys look like they would be good.
http://www.checkcorp.com/seat-heater/seat-heater.asp
I've had other cars with heated seats that warmed up faster than mine do. The high setting is too high and then I either turn it off or put it on the low setting, i find that the heated steering wheel gets too hot and i shut it off. I was in an Audi S6 this morning and its heated seats are adjusted by a dial.
It appears that there are many 7th gen owners who are pleased with their heated seats. I bet they get nice and toasty. It appears that just as many owners are dissatisfied. Those of you who are dissatisfied have you taken your car to the dealer? Under warranty? Was the problem repaired? Were you able to compare how your seats function with ones from other 7th Gens?
Does not seem right that many owners get properly working heated seats while others have to make do with ones that do not work at all or do not provide adequate heat. It’s as if you purchased an iron that does not heat enough to iron your clothes. I would say that the iron is defective as are the seats.
Heated seat problems are now hitting Toyota. All Toyota dealers have been ordered to stop selling all Camrys. Avalons, Civics, and three other of their offerings with heated seats, because some non-fireproof materials were built in right next to the heating coils.
I suppose there could be such a thing as too much heat from a heated seat?
Heated seats have been around for 30 years or longer as have heating pads and electric blankets. The Maxima uses leather for the seats, this is not the issue. Try sitting in some of Nissans other models I bet the seats heat just fine. .
03VQMAX
09-25-2015 04:19 PM
jerrod99_se-l
08-27-2015 08:27 PM
ViciousVQ30
08-05-2015 05:40 PM
