Factory amp or not in 2012 maxima s?
Old 12-09-2013, 06:35 PM
MsFinni's Avatar
I'm looking at upgrading to a new radio for my 2012 maxima S and the salesman is asking if the car has a factory amp. I don't know.. how do I tell? This is the upgrade I'm looking at buying -
Amazon.com: Oem Replacement In-dash Radio Dvd Gps Navigation Headunit for Nissan Maxima Teana 2009-2013 with Rear View Camera: GPS & Navigation Amazon.com: Oem Replacement In-dash Radio Dvd Gps Navigation Headunit for Nissan Maxima Teana 2009-2013 with Rear View Camera: GPS & Navigation
MsFinni is offline
Old 12-09-2013, 07:18 PM
maxipad2011's Avatar
I would assume that if you haven't altered it at all, then it is factory.
maxipad2011 is offline
Old 12-09-2013, 08:16 PM
Tommy6905's Avatar
If your talking about the rear "subwoofers" then yes there's a little amp back there.
As far as that unit your looking at goes, I don't think it can be intergrated as a simple swap. But if it's done a lot of people here will be interested
Tommy6905 is offline
Old 12-10-2013, 04:31 AM
RCM78's Avatar
The Bose system has an amp in the trunk under the rear deck. If the speakers in your rear deck say bose on them then you have that system.
RCM78 is offline
Old 12-10-2013, 07:33 AM
Tommy6905's Avatar
The s model has a amp and subs in the same spot just not Bose tho
Old 12-10-2013, 11:50 AM
smooth703's Avatar
i never knew the S model had a subwoofer doesnt sound like it
smooth703 is offline
Old 12-10-2013, 12:26 PM
Tommy6905's Avatar
Ya those 6x9s in back are considered the subwoofers, we know they aren't but that's what they call them. If u look in the trunk of an s model you'll see it's setup the same as the Bose system with a amp.. Also I'm pretty sure the s model system is made by clarion so it's half decent
Old 12-10-2013, 01:25 PM
Boslax6123's Avatar
So ppl's with the base S can tap into the factory amp and draw power to an aftermarket sub..??
Can this be confirmed...?
Boslax6123 is offline
Old 12-10-2013, 02:59 PM
Tommy6905's Avatar
I doubt it's enough power to handle a sub, maybe a small 8" sub...everybody with the s model on here look in your trunk under the rear deck carpet you'll see the little amp I'm talking about
Old 12-11-2013, 10:37 AM
Warriors55's Avatar
Actually you can consider them subs, kind of lol. According to the FSM, the rear deck speakers split off to a small low signal converter or low pass filter which goes to the stock amp. All other 6 speakers will run off the headunit.
I have a 2013 Maxima S and swapped the speakers in them so I did some research to see how the system was wired.
Warriors55 is offline
Old 04-18-2024, 01:44 PM
ralph078's Avatar
Maxima s amp wire diagram
[QUOTE=Warriors55;8888047]Actually you can consider them subs, kind of lol. According to the FSM, the rear deck speakers split off to a small low signal converter or low pass filter which goes to the stock amp. All other 6 speakers will run off the headunit.
I have a 2013 Maxima S and swapped the speakers in them so I did some research to see how the system was wired.[/QUOTE
ralph078 is offline
2k11ApexEvo
03-30-2016 06:54 PM
ef9
08-14-2015 03:03 PM
Mcnabb34
08-11-2015 08:45 PM
Superbform
08-11-2015 08:10 PM
MikesChevelle
08-06-2015 11:36 AM
Quick Reply: Factory amp or not in 2012 maxima s?
