Rotor and pad replacement issue
This past weekend I replaced all rotors and pads and all hardware associated with the replacement. After doing so there has been a pulsating issue when braking only above 60 mph. Also, there is not a vibration issue when just driving without braking. Any ideas on what the issue could be. My only assumption is maybe a bad rotor, but is there a way to figure that out without replacing one at a time?
I know the vibration without braking cannot be tires or alignment as I just had brand new tires put on 5K miles ago and just had them rotated. The vibrations only occurred right after the brake job.
Any help would be appreciated.
BTW the car is a 2009 Sport model.
Thanks!
Thanks!
yea duralast is okay. id double check on the installation then. take the rotors off and make sure the wheel hubs are clean - scrape them with a wire brush if they're rusty. torque all lugs down to the same exact spec. then follow duralasts bed-in procedure; im assuming you bedded them in? its very common for new brakes that werent bedded in correctly to vibrate
Is there anything I can do to correct this or do I have to buy new pads and rotors or live with it?
I would do as suggested first and make sure everything was installed correctly and tightened back up properly, including the lug nuts. Ive been doing my own brakes for 10+ years and never "bedded" them either. But, I just replaced all my rotors and pads with Powerstop products and they made it very clear in there instructions to "bed" the brakes after installation. This is my first set of slotted and drilled rotors, so I wasnt sure if that plays a role or not.
Any other suggestions?
be sure to torque wheels properly. Overtightening the wheels can bend the hub section of the rotor. That can and will cause vibration when you are both on and off the brake pedal. Like the other guys stated, check the calipers but also check to see if the slides are moving. if you have a frozen slide (stuck not cold) it will cause a pad to stay applied and overheat everything.
Sorry to bump this post... but does anyone know the bolt size for the caliper bracket? I want to change out the front rotors this weekend.
When I replaced my brake pads, I noticed the stock ones had two metal shims. I re-installed the outermost one on the new pads (Duralast ceramic). So far no noise or squeeking. I also used moly grease on the back of the pads. Maybe this will help?
Also, remember to clean the new rotors with brake cleaner, as they come with a thin layer of oil that you need to remove.
RealityCheck
08-05-2015 06:18 AM
