17" Stock 2006 Maxima Wheels on 2009
Looking to mount a 17x7 stock wheel from a 2006 maxima on a 2009 premium. The tire is a Blizzak ws 60 and size is 225/55/17, I don't think there will be any fitment issues but I can't find anyone on the .org that's done this. Will they fit???? Does anyone have any red flags to watch out for of the tires?
Also does anyone know if the TPMS will be compatible? How much should I torque the lugs to when installing them?
Thanks ahead of time!!!
Yes sir they will, although I'm not sure about the offset of those wheels! I can't answer if the TPMS is compatible, hopefully someone will chime in! As far as torque, I usually go to 80lbs, but I know it's more than needed, I think the manual calls for 70-75lbs!
I'm using some aftermarket 17X7 winter tires/wheels, just make sure the wheels clear the brake calipers. For just winter use I never really worried about the TPMS as they aren't on the car for an extended period of time anyway.
Thanks for the replies!
I ended up getting some 17" steel wheels that can accommodate large calipers with 225/55/17 Falken Eurowinter Tires. Didn't bother doing a test fit because they were such a great deal that if they don't fit it will be easy to resell them with winter around the corner.
Apparently a 225/55/17 tire on a 17 wheel is similar in size to the stock 245/45/18 on 18 wheel so I'm hoping there will be no fitment issues.
dank4us
04-01-2019 04:06 PM
MAXSE5SPD
08-23-2015 12:06 PM
laparka66
08-06-2015 09:36 AM
