Valve tapping at cold start ?? Anyone else?
Noticed a tapping sound from the engine at cold start this morning that went away after about 10 seconds. I run Mobile 1 full synthetic 5W-30 and verified that it was full of oil after I heard it. Just wondering if anyone else had experienced this? It's an 09' with 48K on it. It's hard to imagine that I'd need to get the valved adjusted but who knows.
Thanks in advance!
Thanks in advance!
Hmmm...low miles, full of good oil...did you drive it in a fashion to do any damage before shutting it off? How long was it off for? What was the temp outside? I have owned multiple VQ's and have never had a valve tap on start up...see what happens tomorrow morning and report back
Originally Posted by GSB Maxima
it's an 09...aren't you supposed to use the Ester oil? BTW I'm new to maximas and i myself an trying to find out if that oil is a MUST?
However, if your car is still under 15K miles, use conventional. It's better for the break-in period.
Sorry OP, didn't mean to thread jack. Hopefully someone more knowledgeable can weigh in on your issue.
48K that's too low for valve adjustment :S My previous BMW M3 had 200,000 kms and didn't need valve adjustment..
Use Nissan oils, they're tested and verified obviously.
As for Oil debates, as Serpent said, you'll get no where, its a never ending debate and discussion. Same thing happened to me when I had my M3, the topic about two different oils had more than 3000 posts, and each one had a different opinion lol!
A good tip, before switching the car off, let it cool down for 30 seconds then do so. Also, when you start it up, wait for 30 seconds before you rev or take off.
Good luck
Good luck
Here's an update.....
This morning, the tapping noise did not happen on a cold start. Both mornings, the car was in a closed garage. The morning that it happened was colder, but probably only around 35 in the garage compared to around 48 this morning. Both mornings, the car had only been off since around 5:00pm the night before and in both cases, I did not drive the car aggressively or in a way that could feasibly cause any damage before shutting it down. So the only difference seems to be that it was colder, but I've left my car outside the garage on 25 degree nights last winter and never had that tapping noise. It's a mystery for sure I guess I will see how the coming days go.
As for the oil discussion, I think folks summed it up pretty well. I'm quite meticulous and over-analytical so I got caught up in the countless hours of reading the various posts on here about it. At the end of the day, after breaking in with traditional oil, I went with M1 5W-30.
Glad to hear another good cold start. Remember at the end of the day it is a machine and can/will have a little quirk every once in a while...
Its odd but I had a one time thing where I was home in NY, started my car up and my engine sounded like the valves where tapping, it might also have been it was freezing out, I had the radio off and the heat did not kick on yet so ever sound in the car was magnified, I just figured it was an odd combination of things, cause the following days my car was fine on start up.
03VQMAX
09-05-2015 03:47 PM
trungg86
09-04-2015 04:58 AM
