Gauge pillars
Gauge pillars
Anyone here has added additional gauges?
I am not really a big fan of multi gague pillar, but i would use an extrage gauge for the Battery, since we dont have that.
Any recommendations if you have added one?
Thanks!
Thanks!
^ too much time that i already dont have! plus these are so common, i was just seeing if there is one that might not be listed for our maxes, but from other cars that do make a perfect fitment.
BTW ^, did you make your own FB bass enclosure? you know where i am heading with this question
I considered this myself for a hot second... then remembered we have side curtain airbags in the A-pillars which = no go unless you want that stuff exploding in the cabin if someone t-bones the drivers side.
If you want additional gauges in the car, I'd look into a 2 or 3 gauge hooded pod to put on top of the nav hood in the center stack.
Here's an example of the gauge pod I was considering:
http://www.glowshiftdirect.com/Unive...-Dash-Pod.aspx
And some gauges to put in there:
http://prosportgauges.com/amber_whit...ce_gauges.aspx
unless you have a turbo or something i dunno what you'd need the gauges for.
i use an app (Torque) with my android tablet that connects to the ECU using a bluetooth OBD-II adapter (from eBay) and pulls all the regular stuff for me (MPH, IAT, coolant temps, throttle position, etc etc) and you can create digital gauges or meters or whatever. also lets you make videos and overlays with the data from the ECU, pretty sweet.
If and when I decide to install a trans and oil cooler, that'll be the time I hook up some dedicated gauges to read the powertrain vitals.
I have an OBD-II data scanner with real-time data and capture capabilities... but would rather have a 3 gauge pod for oil temp, oil pressure and water temp. Call me crazy, but I like knowing what's going on under the hood at all times
Gauges are very helpful for people who drive aggressive
the top things i would use the gauges for are
Engine temps, CVT temps, and Wideband for tuning (but some of us dont know wtf they doing so they ask why do we need them)
CVT/Engine temps being top on the list
what i would do is get some AEM and mount them on top the the screen in the center of the dash which i feel is a perfect spot for them just have them facing you on a 45degree angle ...which is what im going to be doing.
hmm i will be interested to see how that looks. I was actually looking for a single, Voltmeter gauge.
How small do these gauges get? i wonder if there are flat LCD type gaiges available, this way you can mount them right on the screen or like in the corner of your cluster protective clear plastic cover
http://prosportgauges.com/45mm-gauges.aspx
you can build digital gauges using a smartphone or tablet for about $44 to pull any info from the ECU you want. notice i didnt say "i dont know what they're for" but that i said there is no reason to spend the money for something you can do with an app, and who doesn't have a smartphone these days?
the only reason you'd NEED physical gauges is for anything additional you added to the car that you can't pull from the ECU. and even then you're adding gauges to a 4 door family sedan which im sure will make the interior look super classy
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
