any way to disable the 15mph autolock?
i thought i found it, but it seems like the only thing you can change is if the car automatically unlocks or not once you shut it off. otherwise, as far as i can tell we are stuck with autolocking. i hate this feature and have disabled it in every car ive ever had. its just annoying.
I searched but didnt really come up with much. thanks guys.
EDIT: I found it in this PDF.
http://www.nissanusa.com/pdf/techpub...Altima_QRG.pdf
They actually dont mention it in the regular user manual, only the ignition autolock that i mentioned above. If you do the same procedure in the manual with the LOCK button, it disables the 15mph lock.
try this...
while car is on "ON" mode, hold down door lock switch to "lock" position for 5-10 secs... you will see your signal blinkers light up twice(?)..
not sure but that's what i tried quite a while ago....
Originally Posted by Stlbluzoo11
why dont you like the feature?
My girl's car has that feature...Its simply annoying. I'm glad my 4th gen doesn't have it.
I totally understand. It annoys me when I am on my girl's car.
But I love it. And I really appreciate that the doors do not automatically unlock when I shut off the car. When I'm stopping anywhere near Atlanta, I shut off the car, then look around carefully for several seconds before I dare even crack the driver's door, and absolutely do not want any of the other doors to automatically unlock.
rbaker100
08-31-2015 11:09 AM
