Foud a neat trick with the paddles
I havent seen this posted anywhere so forgive me if it is a repost... if you leave the shift slector in D and use the paddles to downshift as when comming to a stop sign or having to slow abruptly, if you hold either of the shifters down, in 1 second it will automatically shift back to D in normal drive mode. This is much quicker than not holding the paddle down and letting the transmission decide when to put it back into D mode. Hope this helps those that use D mode most of the time and want to ocassionaly tap the paddle to make it do what you want in that specific moment without having to move the selctor and take your hands off the wheel.
it is perfectly fine to downshift using the transmission (paddles or the shifter). i asked a Nissan master tech and they said the car actually does it on it's own a little when you brake.
Jimm - awesome info thanks! I always used to push my shifter from left to right to force my car back into D. This will be nice to not have to take my hands off the wheel anymore! Thanks!!
No problem, even though I cant contribute as often as you Ghozt I definitly enjoy supporting the comunity. General manager for best buy and a new daddy... My time used to be all about cars, now its a little more tied up...
I noticed this immediately when I began driving my 6th gen '04 SL, and was glad when I found the same system exists on my 7th gen '09.
Maxima2010 Prem
08-13-2015 11:34 AM
