LED Gauge swap
LED Gauge swap
Anyone know what bulb size are behind the instrument cluster? Haven't pulled the cluster out yet but was curious if anyone knew yet so I can order before construction begins.
Thanks!!
Thanks!!
Then I suggest to just go with a RED color so it wont be far off from the rest of the gauges and interior lights. I have to take my cluster out anyway this weekend and will be taking notes of exactly which leds will fit and work correctly in the cluster.I also want to change the mood lights in the door handles and the 1 in the center of the map light that lights the shifter.I think those alone would make a big improvement.Lastly the key fob and push start buttons are the last 2 items I want to mod with different led's.But those 2 may need to be soldered in.
My friend just swapped out the entire LED cluster in a Cube and if the Maxima is anything like it, everything will be swapped out including the controls in the center stack. Fingers crossed.
Key fob holder on left side I meant to say.Sorry.If you look at it ,it has a few lights and they blink at times. It would look good if the color were changed to something different.
the GT-R button lights up just a tad. And I am sure where it says start on it it is clear in that section so you can put blue led backlighting if you want. I already took it apart to check. I just plan to make mine a lil more solid red rather than blue thats all. Give it a whirl.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
doctorpullit
10-28-2019 10:58 PM
HerpDerp1919
09-29-2015 02:02 PM
