Led interior issue
Led interior issue
I have the interior LEDs but I notice they glow a bit when they are off. If I tap the dome light lightly they all go out but come back on randomly. Think it's just a loose connection with a bulb?
i seen this issue some where but. thats normal. mines do the same thing its because the led require less power to be on so any little current going to them it will show a little. it will not kill your battery no need to worry
normal for leds, they require a lot less power to get going, so even when your car is off there is some current still flowing so it glows a little. You nave nothing to worry about, thats normal or the leds
I posted about this .The leds in the rear headliner always stay lit a lil when car is off and while driving. The door trigger sensor has a slight voltage going through it at all times.Nothing to worry. If you want them off use a Diode on the door trigger wires and it will go away,but that is extreme.The feedback they get from the cars BCM is a normal operation and nothing to worry about.
jds22
09-04-2015 01:52 PM
