How To for the DIY'er: "ledbulbz" Bright White LED Bulb Install
#41
How many circuit boards came in your package from this seller? If you had 4, why not use that to have all the same light in the interior? Here you find the pics as promised. I was off today and decided to take pics.
Car in garage, garage door closed, very dark in garage so I could catch led's ouput, but flash from camera produced a lot of light with the light from led bulb makes it look soo bright.
#42
MiDiablo, thanks for the write up. Saw your post and went and bought the 180 led kit from LEDBULBZ. Got it all installed and it looks great. The 180 led kit is bright for sure and a nice white with a slight blue tint. The only thing left is the reverse bulbs since it's a pain in the rear to get the rear taillight out. Anybody have luck or advise taking out the taillights? The 2 hexnuts are out but the tabs are pretty stubborn to push out.
#44
#45
Yes, I stuck the trunk board to the carpeting stuff.
Well, I just got my order of leds from HongKong, China. That thing is BRIGHT!!!!!!!!!! Order took 14 days to get to me. I am very pleased with it. I hope they can last me more than a year.
If you want great light output, buy circuit boards! I got the 15 leds and 13 leds. The 15 is blinding! Real room light in your car. The 13 is super bright too, but a little less than the 15led. I will take pics and post.
#51
I bought the kit, got it in the mail yesterday and installed it this morning. Took less than 20 minutes and that included 2 or 3 minutes getting the tools out.
Since it's day time I can't comment on the brightness but getting rid of that stupid soft yellow color already looks 100X's better even during the day. Thanks again for the sweet write up...made it a breeze to install.
#53
I ordered my LEDs from V-Leds.com, i purchased 7 pairs of the 194 5-Led light (14 total LED lights), and they work great. I bought them in white, they make a huge difference, and i'll try to get some pics up soon. I have 13 lights installed so far:
4-Door light
2-foot lights
2-license lights
1-trunk light
2-front map lights
2-rear map lights
The 14th light was for the glove box, but i have no idea how to get to it. Has anyone here replaced that light or know how to get to it? Thanks in advance.
4-Door light
2-foot lights
2-license lights
1-trunk light
2-front map lights
2-rear map lights
#54
I've ordered the 180 LEDbulbz kit. I put 2 of the 12 LED circuit board in the front Map lights as it make for a nice spread out look. The 24 LED bulb that were intended for the map lights I put in the floor. I may switch those our for some blue 24 LED bulbs that I ordered. I have no idea how to get to the backup lights however. This whole LED thing was a great Idea, and the assortment you can use means that you can find something that you'll really like. Just needs some Ideas on the backup lights. By the way to get the 24 bulb LED in the floor lights you need to twist the socket out, then put the bulb connection end thru the hole, push the connector on then retwist the connector back on. You can't get the 24 LED bulb all the way through the the hole left by the connector, only the end of the bulb, just enough to push it onto the socket!
#55
wow,I just bought this kit off ebay yesterday and was going to post on it but now i see there is a thread on it already.lol. I also see there is a 3 day sale from this seller and the full kit is $89 now.I cant wait for it to come in.
#56
Glad to find this post! Looks easy to do with these great instructions. Great job! I am waiting for my 2010 maxima sv premium to be delivered to me in just a few days. Was reading about this stock so called mood lighting included but nothing to be drooling for it seems.. I have a 2008 dodge avenger r/t that came with the blue leds, lighting whole interior bright and loved it. It is a must to have in the maxima to me and for $40 on ebay ledbulbz. they are perfect for just the inside minus the mirror/sun shades.... Great info here and look foward to having these in my new max~
#57
Yeah it is a great kit and good seller . I had a few bulbs that were defective and lighting on and off but the seller sent me replacement ones at no charge. The rear backup light is a pain. You have to pull the carpet lining to reveal the 2 bottom screws that you have to use a socket wrench or wrench to unscrew the screw nuts. There are tabs that are towards the lower and upper rear of the taillight that I used pliers to pinch so it will release the taillight when removing it. I used a hammer to lightly tap the screws on the taillight until it was loosened enough to pull out the taillights.
#61
I installed this kit from ebay and I like it very much.My interior is very bright now.I just dont like the rear map light led boards that just sit there.I want to mount then somehow cause when the bass hits they rattle around in there.
I also still want to figure out whats needed to do the front and rear parking light/turn/brake lights.
#63
After I seen another member say this i did it today and love it. I switched the board leds from rear to the floor lights and it all looks well balanced now.very even light.and might i add the door lights are enough to see when exiting at night.
! poor effect is all the dome lights look cheap due to the frosted lenses.and the hot glue used for the inserts of the board melts off and drips.
NOW I just need to find all the proper blinker leds and digital flasher if needed.
#68
Please if anyone can confirm this on any led kit you may have: in the total darkness do your rear map lights have a tiny glow?I noticed my rear map lights stay on just a tiny bit.ifyou switch the dome light switch to off and not the door they will go out totally.its not very noticable but they do indeed stay on.
#69
Also, which lights did you use for reverse lights, and are those also brighter than stock?
Last question, are the provided license plate lights bright enough? Do they look like OEM Lexus, etc?
Thanks again.
#70
the rev lights came withthe ebay 180 kit. not bad looking but i would get the next step up led bulb they offer.
the plate lights are very nice and yes like lexus.they fit niceley as other led tower 194 style bulbs wont fit like other cars so these they have are perfect.
the map lights are about the same. the mirror lights are real bright. open the visor mirror if you need to read anyhting.
#72
LED bulbs set
I have my trunk completely torn apart right now, I have installed the entire set except for the reverse lights. I have removed the liner and the two nuts that are securing the tail light there is a brong sticking into the trunk close to the tip of the tail light that points towards the front. I would like to finish but I can't seem to get the light assembly out without feeling like I am going to crack it!!! please help
#73
Just recieved my set of ledbulbz. I must say i am impressed with the look!!! I know they arent the most bright but they sure look dam good over the stock and all the chrome parts around the dash gleam real nice. I got them for $35 for the 72 led kit,I made a best offer to the seller and he accepted that rather then buy it now price... It should have came with 13 led's total but im missing 2 and only have 11... He was supposed to give me the free license plate ones which i have, But still missing 2. I emailed seller waiting for reply. No biggie i didnt put the plate ones and instead used them under dashboard. Thanks for the great instructions here and information on this thread for the LED's..
#77
It's funny because right after I installed everything and came back in, I had the same concern, will they dim. I'm not sure I will check later tonight if no one else posts.
Also, I just did the 180 LED kit. I didn't do the reverse lights because I am going to be replacing the signals also so I want to do it all at once. Everything else went pretty much as noted here in this great write-up. I just wanted to add some very simple pics of the visor install which are not part of the original write-up. I also decided to use the LED panel for the front map lights instead of the rear. That's where I wanted more light.
Remove the plastic cover by pushing down from the top and pulling away
I just used the screwdriver to pry off the bulbs. They came out easy and would hang from one clamp and not fall down so easy to remove after that.
Here are the LED visor lights
After install. Nice and bright even in complete daylight.
#78
If I do end up buying these...(waiting for your reply to see if they dim or not)......I'll probably buy them in 2 separate colors. One set in blue for the "under dash" lights and white for everything else.
Kinda like this guy.
http://www.cardomain.com/ride/464988
I wonder if his bulbs would fit our 7th gen. I trust Japanese products a little more than Chinese products.
#79
