View Poll Results: Are you committed to buying an R2C Intake once available?
Voters: 119. You may not vote on this poll
R2C Performance Products Intake
#761
Wow okay so I used my Droid app torque while connected to the ECU and was monitoring a gauge that tracked air intake temperature while driving. While cruising along, the air intake temperature was 49-50 degrees Celsius. When I stopped at a stoplight though, in under a minute it rose to 62 degrees Celsius before the light hit green. That's a hell of a temperature increase, and definitely confirms what others have said that these short ram air intakes pull in quite a bit of hot air. Going to do some tests and put the stock box back on and see how it compares...
#763
Enjoy it. I had it but sold mine. It sounds very nice and looks cool under the hood. It is especially nice as on low speeds, you don't hear it until you floor it. But now you will see a dip in gas mileage.
#764
Dip in mileage and power the hotter it is outside and the harder you're driving. My engine bay gets so hot during the day after a drive that parts of it are too hot to touch with bare skin. It's pulling all of this blazing hot air into the engine...
#767
Not me, I noticed a gain in mileage. Over the last 1000 miles with my RC2 in place doing the same driving I always have done, I have noticed .5 mpg increase. From 23.9 to 24.4 average. If nothing else, I am even getting on it more often as well.
#769
#770
Hmm, interesting. Mine is pulling in air temps of 75 degrees Celcius (167 fahrenheit) and higher which according to how engines work results in a worse air to fuel ratio and lower fuel economy/power compared to stock. I'm actually taking my R2C off today and going back to stock, if anyone wants to buy it hit me up.
#772
Increased temps mean lower power too. I only feel a power gain when I'm driving at high speeds and air is rushing in through the grill. Other than that I actually feel a power loss. Has nothing to do with R2C, I had the same power loss with my Takeda too.
#773
Just a question- does the R2C utilize the factory fresh air duct like the Stillen system?
#774
Right on the money. I have a OBD Scanner and data logger with realtime stats on every component. Last week in the DC heat, IAT's with my Stillen intake were about 115-120* with the A/C running.
#775
It fits up against it with the heat shield, but like the rest of the heat shields it is open on the back/sides so ultimately it has no function. The only way to get cold air is to put the stock box back on which seals to the front grill duct and pulls air through there even when stopped. These ram airs rely on the car moving to be getting anything but extremely hot air so anytime you stop it will start instantly rising. For people who doubt it, feel free to grab an OBD scanner and see for yourself - I didn't believe it until I saw it first hand but yeah these ram airs are definitely worse than the stock intake in every way except for noise - if you like noise they're better.
#776
Wonder how hard it would be for a company to fabricate a shroud around their filter that is actually sealed and connects perfectly to the grill air inlet. Heck they could probably even use the stock filter to make their design off of, just get rid of all the twists and turns and widen the pipe a bit.
#777
#778
Might not be on there that long, I'll be doing some testing and getting some temp and other readings with the R2C, then again with the stock box, then again this weekend when I build the CAI. I'll def post a new thread up with all the results so people looking for intakes can make an informed decision.
#779
Wonder why the option of pulling some freah air in from the "cowl area" of the cars hood hasn't been explored? It was done with numerous muscle/race cars in the past and seem like this vehicle might have some potential as long as the plastic/waterseal is not compromised.
Just wondering...
Just wondering...
#780
Just wondering...
Just wondering...
If I didn't think a NACA duct would absolutely ruin the look of the hood, I'd say that would be your best bet for bringing in fresh air, especially at speed.
#781
My Fujita CAI on my 06 Maxima changed the color of my oil (GC 0w30) the oil immediately turned dark black within a few hundred miles of my oil change, my used oil analysis said the oil was doing an excellent job of absorbing heat, but I never experienced this color change until the intake. I never did enough UOA to see if this heat increase effected the oil life
#782
#783
My 09, I drive like 3 miles to school each day, so right now an intake might not optimize anything for me
#785
any advice
any one have some advice for a tuning neewb... i normally like doing audio stuff like woofers and some nice components, but with a car like this i cant help but try and get as much power out of it as possible. I got my max in the past couple of months and have been adding stuff to it little by little.. it was an upgrade from my 04 altima and the pickup is rediculous! adding an intake to it can only make it better.. after reading through the forums looks like ill be going the r2c route and was wondering if any one had any advice on installing it or anything i should be prepared for when removing the stock air intake?? Thanks for your help in advance...
#786
#787
Still Happy
I've had my R2C intake on since last year, got one of the first ones made...and I'm still very happy with it. The engine sounds amazing...and the pull is great too. Don't have b4/after numbers to give, or adive for installation...but it is supposed to add about 9hp. The installation instructions I got were a little fuzzy, but after studying them I figured out everything and didn't have a bit of problem with the final installation job..and I'm no mechanic. Mine is a lease, but I'm going to purchase it after the 39 months is up, so my mods are staying with me...plan on getting a Bully Dog next, or a Racingline Y-Pipe...
#788
not sure if anyone still interested in R2C, but it is instock @ $180 + Shipping.
http://www.r2cperformance.com/nissan...ke-system.aspx
Dasmith
09-23-2015 08:28 PM
Keyno McMike
09-21-2015 07:18 AM
pears
09-18-2015 05:25 AM
