Low voltage while running.
05 SE, 107k miles. My month old battery was very low on voltage, had it checked and they replaced it. Car is now running correctly but when I put a voltmeter on the battery at about 1500 rpm, it's only reading 11.89 volts (11.82 volts at idle). With a good alternator it should be about 13+, right? Bad alternator?
Noticed a smell like burning plastic or rubber so as I would be replacing both belts with the alternator, I pulled the belt and while spinning the components by hand there was noise from the idler pulley. Replaced the pulley and both belts, didn't fix the problem so alternator is getting on order. Nissan didn't seem to be very concerned with maintenance when they designed this car. Have to pull minimum the fans, maybe the radiator, and maybe the AC compressor? That's a bit much..
I saw this in another thread as well. Why is the alternator so apt to take out batteries? I'm guessing that's what happened to the first battery, but how? Just because it's not charging shouldn't damage a battery.
When your alt begins to die, the battery is constantly being depleted and stressed at a lower SOC than it was designed for, then charged, discharged, over and over until eventually the alt dies completely, resulting in a battery that will no longer hold a charge, or now has a significantly shorter life span due to the chemistry-killing charge/discharge cycling.
AaronL
12-22-2016 07:07 PM
TWINTRBO
01-14-2009 07:01 PM
