Service engine soon light
Old 08-31-2018, 10:56 AM
Tamburitzan's Avatar
i have a 2005 maxima. The service engine soon light is always on. The fault codes display an error with the mass air flow sensor. I have changed the A/F sensor numerous times and cleared the fault codes. The service engine soon light comes back on with an A/F sensor fault again. I have cleaned/changed the air filter and made sure the air ducting is connected.Any suggestions?
Tamburitzan is offline
Old 08-31-2018, 12:13 PM
Davisnathan49's Avatar
Have you checked the wiring to the harness/plug? Could be a loose wire. Check the wires for any damage.
Davisnathan49 is offline
Old 08-31-2018, 12:31 PM
Wires seem to be in good shape. I also cleaned the contacts. Thank you for your response
Old 09-02-2018, 01:09 PM
Costee's Avatar
Are you getting an error for the MAF or A/F? What exactly is the code?
Costee is offline
Old 09-02-2018, 01:44 PM
Thank you for responding
it changed from MAF to A/F. I did the relearn procedure for the ECU
Old 09-03-2018, 02:14 AM
Costee's Avatar
What was the precise code?
Costee is offline
Old 09-03-2018, 04:43 AM
P0101. MAF sensor replaced. Then p1273. Mixture relearn procedure done. SES light goes out for a few days. Then fault codes above return
Old 09-03-2018, 05:51 AM
Costee's Avatar
Check for tiny leaks around the A/F sensor and manifold area.
Costee is offline
Old 09-04-2018, 03:47 AM
edjose17's Avatar
Usually a dirty throttle body will cause this code.
edjose17 is offline
Old 09-04-2018, 03:57 AM
Costee's Avatar
I doubt, and any attempt to clean it is most likely to open up fresh issues.
Costee is offline
Old 09-04-2018, 09:24 AM
Thank you all
Old 09-05-2018, 04:21 PM
Throttle body
Would a faulty throttle body cause this problem? I do have a new one I thought about installing
adsinclair
03-22-2013 07:12 PM
Louie Max
04-29-2007 06:29 PM
BIGHANK
02-11-2005 12:19 PM
a33
11-22-2001 07:49 PM
2THEMAX
10-20-2001 03:12 AM
Quick Reply: Service engine soon light
