Noise from under dash (HVAC/heater), please help identify (video)
Old 12-26-2017, 09:23 AM
DMAXI06's Avatar
Hello!
Please help identify the problem with my Maxima's HVAC unit.
The noise has persisted for several years, worsening each season.
NOTE: I have changed the actuator for the passenger side already to no avail. In the video, all functions performed worked as planned (heat/cool,modes all function normally). The issue seems to be with cabin vs fresh air.
Thank you!
DMAXI06 is offline
Old 12-27-2017, 08:22 AM
Doc Plus's Avatar
I checked the ATC section of the service manual.
On page ATC-34 there is a schematic which tells you where are located the different motors.
What I will do is to access each motor to find the one which makes noise. If I found one I will unplug it to see if the noise goes away.
Because of the noise location on your video, I will first check 2 of them: the "air mix door motor" on the passenger side and the blower motor.
Doc Plus is offline
Old 01-16-2018, 11:29 AM
Roymg's Avatar
Originally Posted by DMAXI06
Hello!
https://youtu.be/lg24IeAepK0
Thank you!
Sound like a leaf against a fan blade.
Roymg is offline
James92SE
09-21-2010 07:00 AM
nismopc
05-28-2006 09:12 PM
limsandy
05-13-2005 07:23 AM
steelymatt
04-11-2005 08:17 AM
seno76
09-18-2002 06:54 PM
Quick Reply: Noise from under dash (HVAC/heater), please help identify (video)
