04 Maxuma tough start when cold
Well, that's no limp mode. As I said it's probably the fuel pump that's on its way out. The fuel unit is made up of a fuel pressure regulator; fuel level sensor; fuel filter; and fuel pump. I believe the pump fails once it gets hot. If you had cold hard starting I would point to the fuel pressure regulator.
Take the car to one of those places that test batteries and alternator. If it's cold your CCA is probably low meaning that you'll need to replace the battery. If you're battery is brand new and your alternator is bad you'll reduce the lifespan of the battery. As for the car not reving it's cuz it's in safe mode and you'll have to replace your MAF sensor. You should definitely get someone to test your components. Good luck.
If one battery cell failed you wouldn't be able to crank the engine at all, it's not that.
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
trungg86
09-04-2015 04:58 AM
