Shocks and struts
Shocks and struts
Soo i bought my car at 63000 miles now im at atbout 118k never changed these. I was thinkin bout buying the parts and then finding a mechanic to do the work... Can anyont point in the right direction as to what exactly i need? Websites and how much from experience has this type of work costed?
Its a 07se also do i have to both front and rear ??
Or should i not even bother at 118k and ride till the wheels fall off?? Lol
No advice about what to get, but I'm with you on the concept of if it aint broke. Certain things are worth the money, trans fluid replacement, spark plugs, brakes, tires, these are things you gotta do regularly...however if the struts are fine, and you're not looking to lower or race the thing, then save your money.
so i ordered the 2 front struts and the 2 rear shocks and the strut mounting kit....
i went with monroe sensa tracs
is there anything i should order as a precautionary measure to ensure the repair goes smoothly
While is apart change the rubber bushings for the rear shock too.
If you got extra $$ replace the rear sway bar with a progressive bar/bushings.
That's what I did,and replaced the springs. Handles much better on turns.
Stagnet04
10-11-2015 08:16 PM
maxima-junky
10-07-2015 06:13 PM
