How to install an oil cooler on a 6thgen Maxima with video
Wassup fellaz. Don't really come on here too much but I would like to share what I've been doing to the max. Just did my an oil cooler on my maxima yesterday and everything went well Because the VQ's are known for oil consumption I think it's a great investment to slow that oil burn down. Here's a very self-explanatory video that should help with the installation if you ever decide to diy.
I'm really not sure the cause if it. I would assume it's due to oil level neglect causing the piston rings to not be lubricated which is a result to wear. I know the engine cook the oil but I'm not sure as to why. You'll have to Google that.
http://m.mishimoto.com/mishimoto-uni...ooler-kit.html
Here is a brand name, but I'm sure they're cheaper with a no name.
With the fact we already have a line from the radiator cooling the oil I would say no. I use the bigger Mobil 1 105 filter and Am soil synthetic. Not sure you can improve on that. Not sure you need that unless you are towing with your Max.
Or racing. Jmax does a lot of that. The VQ's run hot. This mod is suppose to drop the temp by 50 degrees and if it really does that, then I think its worth it.
MAXSE5SPD
08-23-2015 12:06 PM
