New battery, still no power...
Hey guys, need some help here.
I just installed a brand new battery in my 04, and still not getting any power other than the security light blinking. I looked at those huge fuses on the (+) cable. How do I test those? Also, do I have to check those fuses inside that long box next to the battery? What else should I check?
Thanks guys!
Thanks guys!
Honestly, from reading this, you probably should not check anything and should get your car towed to nissan, really. I think it's best for you and your safety.
Check battery voltage first....
Check alternator charging voltage.
Then check your ground.
Then mess with the fuse block I guess. At this point I would go to nissan, but thats just me. If the fuses fry, there is a problem somewhere.
I said check your ground, did check your ground before buying something else?
I'll next check the alternator, then ground next.
Thanks!
Probably problem is at ignition switch. Turn on and off high beam, if you got power delivered there, but nowhere else, then circuit at ignition switch is stuck open even when you turn your key. Could be faulty chip in key itself, in which case you would need a brand new key, and have it programmed.
06-06-2017 02:01 PM
bigfrank
10-01-2015 12:51 PM
markevans999
09-10-2015 04:29 PM
