wants to replace electronic locks of my car - requires a locksmith
i have my Nissan maxima 2006 and my electronic car locks are quits working. they are no longer working. when i press the button there is no sound or activity of locking. so i want to replace them but i dnt know how much it will goin to cost if anyone have some suggestions kindly share them with me.
If all of them quit working then replacing them isn't going to fix it. They are not all going to break at the same time. Off the top of my head, I believe there is a fuse for the door locks. May want to check that first before spending what I would bet is a crazy amount of money to change all 4 locks only to find out you are still having the same problem.
there is a fuse for the door locks. Also if that isn't the problem, try unlocking from within the car using the drivers side door lock button, then try the other 3 doors. If they work and the keyfob still doesn't work, take the keyfob to the dealer and have them check proper operation. they won't charge you to look at it, but if they have to do any other checks in the car they will. You can also take it to a local parts store, they have testers at the counters. Might just need a new battery. If you do what I explained, and nothing works, then your BCM might be damaged. Might also want to reset the car by disconnecting the battery for 15 minutes then try again.
Lakersallday24
06-16-2019 01:35 AM
King_Ten_Ahead
09-30-2015 04:27 PM
laparka66
08-06-2015 09:36 AM
