can a fluid change prevent trans problems with my 5spAT?
Old 02-14-2013, 06:20 AM
ehunni7989's Avatar
Guys I'm new here... just purchased an 04 Max SE with 127k. Car doesn't seem to have any trans issues... yet. I went to my local Nissan dealership and bought 14 qts of maticK @$11/qt and drained\refilled 4 times over 2 weeks as I read suggestions about here. Trans hadn't been serviced since about 60k miles. Fluid came out dark initially on first couple drain\refills but is very clean now. My question is: can clean fluid help prevent some of the valve body\solenoid issues?
ehunni7989 is offline
Old 02-14-2013, 11:32 AM
L36
L36's Avatar
Well yeah, that's the point of preventative maintenance, but if the fluid was brown, changing it can do more harm than good.
L36 is offline
Old 02-14-2013, 03:51 PM
acercomp71's Avatar
You changed the fluid and you did the right thing. Now, don't worry and don't think too much, you are good for next 30 or 60 thousand.
acercomp71 is offline
Old 02-14-2013, 07:30 PM
smittybizzle's Avatar
Pretty much change it in another 30k .
smittybizzle is offline
Old 02-16-2013, 05:33 AM
Kryogen's Avatar
doing that fixed all my issues, and been good for 2 years now.
I now do one drain/fill every 30 000km or when it starts to be a bit rough again.
Kryogen is offline
Old 02-16-2013, 10:59 PM
frytryout's Avatar
good info to me ,Now, don't worry and don't think too much, you are good for next 30 or 60 thousand.thank you,
frytryout is offline
Old 02-17-2013, 02:30 AM
RAINMANYEH's Avatar
With your trans fluid being brown, there are arguments on both sides as to why you or should not have changed the fluid. IMO... You did the right thing. If the fluid was brown, it would appear that the previous owner neglected the car. If it were me, I'd check over the entire vehicle for my own peace of mind.
RAINMANYEH is offline
Old 02-17-2013, 07:19 AM
mrjasonlyrics's Avatar
That's like saying if you change your engine oil will that help. Of course it will . Every fluid in your car does come with an expiration date and engine and tranny is the most costly when neglected. Seeing that you're on the "maintenance" tip and your tranny oil came out dark so it shows clear signs of neglect so you should do your coolant flush, engine oil change, brake flush, power steering flush, and tranny flush to be on the safe side.
mrjasonlyrics is offline
Old 02-19-2013, 04:10 AM
Kryogen's Avatar
well worst thing is nissan doesn't recommend changing transmission fluid ever unless there is a "problem" with it. That's bs to me.
Kryogen is offline
Old 02-19-2013, 01:09 PM
Maxima2008's Avatar
With the 04's to 06's, I would change every 30K. Unless you purchased the vehicle second hand with high mielage and not sure if they previous owner did any transmission changes. I keep hearing that if a vehicle was not getting its transmission fluid changed every so often miles it is better to just leave it as is "after a certain point". I can attest to that. I have a 95 Altima and drive Wifes 02 Altima. 95 has 295,000 miles and engine gave up on me before Transmission did. Repaired engine and transmission still runs. Last transmission fluid change was at 90,000 mile interval. Same for 02 Altima...currently at 175,000 last transmission fluid change was at around 80,000 miles. I don't believe in taking cars to dealership for tune ups after it has reached 100,000 miles. Too costly for dealership maintenance after a certain point. Don't knock me...that's just my belief.
Maxima2008 is offline
Old 02-19-2013, 01:34 PM
L36
L36's Avatar
I would like to see some evidence on that. Any tech who isn't brain dead would never say that. The mainence booklet that comes with the car is there for a reason. Nissan does not spend millions to test everything out to say "Gee dont change it unless it starts giving problems"
L36 is offline
Old 02-19-2013, 05:31 PM
Kryogen's Avatar
could you just please find the page in the "booklet that comes with the car" where they give the frequency for the trans fluid change and post a copy here?
Unless you can do that, I don't really give a crap about your own opinion, thanks.
Kryogen is offline
Old 02-19-2013, 06:30 PM
L36
L36's Avatar
No need to be upset. I'm not obliged to prove anything to you.
Thanks.
L36 is offline
Old 02-19-2013, 06:35 PM
ShocknAwe's Avatar
In reality you should change it and keep it nice and clean but IMO, and I cant stress that enough, my transmission seems to be better with half old fluid and half new fluid. Unless you are the original owner and know for certain that the fluid has never stayed in too long then it is always best to leave about half the old fluid in there when doing a change. Draining all of it and then putting new fluid in there can lead to problems. As for the frequency? I think a half change every 25k or so is just fine. I take pride in my modified 4AT and I can say that it shifts like butter.
ShocknAwe is offline
Old 02-19-2013, 07:39 PM
nsnrider's Avatar
so does that mean you only change half of your engine oil at a time?
nsnrider is offline
Old 02-20-2013, 04:17 AM
Kryogen's Avatar
Thanks.
owned
Kryogen is offline
Old 02-20-2013, 04:18 AM
Kryogen's Avatar
when you "drain it completely", you only drain approx 1/3 anyway.
So if you drain half, you are draining 1/6.
Quite pointless. Drain it all.
Kryogen is offline
Old 02-20-2013, 05:58 AM
rohanmax14's Avatar
I do mine every 15k miles just to be safely. Sooner or later I'm doing transgo shift kit plus Rostra solenoids.
rohanmax14 is offline
Old 02-23-2013, 11:01 AM
Maxima2008's Avatar
You are the first and only person I know who change it that regularly. Are you doing it yourself to save $? But i would honestly change it frequently too just based on the horrow stories I keep reading on 6th Gen auto transmission.
Crazy story. I reside in Orlando. At one point whenever searching for 2004, 2005, 2006 Maximas on craiglist, you would find multiple Maximas for sale with either transmission rebuilt, or new transmission or transmission problems in descirption.
homeyclaus
09-03-2015 06:15 PM
MAXSE5SPD
08-23-2015 12:06 PM
Maxgig
08-18-2015 09:17 PM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: can a fluid change prevent trans problems with my 5spAT?
