new engine or just fix timing chain
Old 07-05-2012, 12:07 PM
Kofi Armah's Avatar
So my vehicle has just hit 171xxx miles. I love my vehicle and really dont want to purchase a new one. Against my wifes wishes i believe i am going to fix it. I have the dreaded timing chain tensioner issue. My question is would you guys just fix the timing chain or find a used engine with lower miles on it. The vehicle is a 2004 which i know is older but i love the benefit of not having a car payment. My old lady drives a lexus rx and thinks i should just bite the bullet and purchase a infiniti fx.
Kofi Armah is offline
Old 07-05-2012, 12:40 PM
Berto210's Avatar
Id say fix it! Im in the same situation with my 01. Im having a slight over heating issue and am thinking its the water pump (hopefully). Ive been contemplating getting a newer maxima, but my heart is saying to replace the water pump and save off getting into a newer maxima....although the new ones are FREAKING BEAUTIFUL!!!!!!
Berto210 is offline
Old 07-05-2012, 07:23 PM
L36
L36's Avatar
Even if you go with a new engine, all VQ35DE from 04-08 have defective tensioners which will wear out eventually and cause noise. If you get a new engine, you shoudl replace the tensioners with updated ones.
L36 is offline
Old 07-07-2012, 12:57 PM
AscendantMax's Avatar
IIRC, not all VQs have the tensioner issue. It was addressed and Nissan started to use chains that are less sharp, as well as a different material for the tensioners.
OP, I would just get your timing chains replaced, as well as change out the tensioners/guides. Expect to pay a pretty penny though, it's a fairly large repair job.
AscendantMax is offline
Old 07-10-2012, 01:23 PM
twentyeggs's Avatar
Screw all this advice, get a race built LS1, squeeze it in, convert to RWD and have the best maxima in the world.
twentyeggs is offline
Old 07-10-2012, 02:23 PM
po8pimp's Avatar
ha, don't tell him that.....
not a bad idea though. I recommend just getting a used 3.7 and installing it. I am pretty sure you can find one out there. No issues with timing chains and should fit right under the hood with no modification. Just my 1/2 cent.
po8pimp is offline
Old 07-10-2012, 05:21 PM
JujuSL's Avatar
how much would a 3.7 go for though. I'm hopefully going to be keeping my car pass 200k so tryig to see exactly what the chanes of that happeneing are
JujuSL is offline
Old 07-10-2012, 05:45 PM
L36
L36's Avatar
...and how would he fit a 3.7 in a FWD car?
All 04-08 VQ35DE have bad quality secondary tensioners that go bad as miles pile up. Its not the chain, its the tensioner material.
The main chain tensioner guide was fixed 06 and on.
L36 is offline
Old 07-10-2012, 07:22 PM
Hmm...did not know that. The Nissan tech that fixed my chain whine issue said the chains were too 'rough'...and Nissan have changed to a chain design that's not as rough on the guides/tensioners.
Old 07-10-2012, 08:18 PM
po8pimp's Avatar
my bad totally messed that one up. Meant to say VQ35HR, was thinking of a 370 at the time lol
po8pimp is offline
Old 07-11-2012, 05:08 AM
Lovemycar's Avatar
Ok so I have a 2007 M35X VQ35DE and I'm also on the Infiniti forumes I havn't seen any post about guides/tensioners could it be a different setup? I did ask an Infiniti tech he siad he doesn't see much of that at all on the M's
Lovemycar is offline
Old 07-11-2012, 06:05 AM
L36
L36's Avatar
HR is still a RWD.
How will he fit RWD engine into a FWD car?
L36 is offline
Old 07-11-2012, 07:15 AM
po8pimp's Avatar
HR is still a RWD.
I thought the new maxima came with the HR engine. I guess not. Seems to be the DE engine.
po8pimp is offline
Old 07-19-2012, 10:32 AM
nsnrider's Avatar
find a low mileage engine and be done with it. You can swap out the chain and guides with the replacement engine as an added insurance. IMO, this would be the least expensive route.
Personally, I would never replace the chain and guides on a motor with close to 200k miles unless i'm doing a complete rebuild. Seems pointless to sink a couple grand into a motor and have to worry about worn piston rings or valve seals in the near future.
nsnrider is offline
Old 07-19-2012, 02:16 PM
L36
L36's Avatar
This, unless you had that engine from mile 1 and babied it with oil changes within its intervals.
L36 is offline
Old 07-19-2012, 06:26 PM
smplyamzng's Avatar
our engines with 60k is no better than one with 200k
smplyamzng is offline
Old 07-19-2012, 07:52 PM
twentyeggs's Avatar
HR is still a RWD.
I've heard of people fitting longitudinal engines in a front wheel drive car. Would probably cost more than the engine on the maxima lol
Old 07-19-2012, 07:53 PM
twentyeggs's Avatar
Acura legends have longitudinal engines and they are front wheel
Old 07-26-2012, 08:29 PM
Kryogen's Avatar
why dont you just purchase an infiniti fx to able to brag like your wife with her lexus and stop bothering us?
do we care what car your wife drives or what she thinks you should drive?
my wife thinks I should drive an suv, do you care?
jesus
Kryogen is offline
Old 09-16-2012, 12:03 AM
pwcman's Avatar
[/find a low mileage engine and be done with it. You can swap out the chain and guides with the replacement engine as an added insurance. IMO, this would be the least expensive route.]
Last summer I did like nsnrider was saying, found a 2005 engine with 50k. I replaced the chains, tensionners and water pump myself. Not an easy job but well worth the effort. Its been one year now, it runs smoother than ever and I have all these extra parts.
pwcman is offline
Old 09-16-2012, 08:05 AM
mrjasonlyrics's Avatar
I'm pretty sure there's nothing wrong with the engine so why replace the whole thing? The chains and tensioner rarely go bad it's usually the guides but if you're in there you might as well change everything so it's good as new again. The VQ35DE engines are very strong and there's a reason why nissan put them in most of the newer cars so to change it when it's not broken will be due to prefference. But i'll be happy to take it off of your hands if you do....
I would really like to buil an engine on the side, add some cams, bigger pistons for when the one in my car dies.
mrjasonlyrics is offline
Old 09-17-2012, 06:00 PM
pwcman's Avatar
Yeah, but I forgot to mention that my original engine with only 85K was sucking one quart of oil every 1000 miles and the trend was increasing. Last winter I found some time to strip the engine completely and confirm that the problem was coming from the weak bottom oil rings on the pistons. Even though they were still loose in the groove, they did not expand at all, zero pressure against the cylinder walls. The other rings were fine. I measured the timing chain against the new one and could see it had expanded slightly, probably from all that slapping on startup because of the broken main guide. Finally, swapping the engine was the best thing I could do at the time.
pwcman is offline
CorollaULEV
30
08-09-2021 08:11 PM
maxinout93
10-27-2015 01:29 PM
MaximaDrvr
08-19-2015 08:20 PM
Balkins
08-12-2015 06:39 AM
Quick Reply: new engine or just fix timing chain
