Vibration Issue
Vibration Issue
Finally got my motor mounts replaced 3 of them thinking that the vibration would stop...Mechanic has checked all four mounts and says they are all fine...I still get a vibtration from the motor though when the engine is idle...Any idea what it could be?
we vibrate!
There is no sound or funny noises that the car is making...I didnt change the back mount since my mechanic took them all off and rechecked everyone of them to make sure they were not cracked or broken even the new ones. Hey thought it was the plugs, which I changed 2 weeks ago and it wasnt that. My car never did this until the mounts were broken and now at idle it will vibrate every once in a while...I'm selling the car so I dont want a buyer to be , why does it feel like the engine vibrates? I would have issue with that myself
Can you hear or feel some kind of clunk or bump when you change from Park to Drive and vice versa?
Have someone accelerate the car while braking and look if there is abnormal backward (toward the firewall) movement of the engine.
Both are symptoms of bad front or rear mounts.
I never leave behind an enemy alive. That rear mount you didn't change is going to byte you.
My mechanic had the car for over 6 hours took the mounts off rechecked to see if they were fine, they passed inspection. , My borken mounts looked like crap so he would know if the rear mount was cracked. He thought it was because the spark plugs needed to be changed, did that and still have it. It feels like a bad motor mount feel....he couldnt figure it out and its driving me crazy, wondering if I got a bad mount, when I replaced it
My car does that too, started about 6mo ago, replaced a bad motor mount, which had been replaced not that long ago. My tech thought it might be the ECU not controlling the motor mount properly. We have an electronic motor mount that varies (hard or soft) when we accelerate. He thought it might have been out of sync. Replaced mount, instead of ECU. It fixed it a little bit, but still vibrates at idle sometimes. Just sitting at a light, I can feel it through the steering wheel.
Nope vibtration seems to go away at idle when i rev the engine... I'll be taking in to the dealer when everything is fixed so i can get a check on it and final inspection for the neext buyer
