Twins or singles
Twins or singles
Hay all
Our 6gens have twin mufflers at the rear. I know twins look good. But im thinking about doing a single muffler setup at the rear. Has anyone done this before a single setup.? Are the twins there for a reason as in for backpressure will i loose power going a single setup?
Cheers Kurt
Cheers Kurt
Hay all
Cheers Kurt
Cheers Kurt
http://www.youtube.com/watch?v=QE9e-GkJI8g
See below for dual setup ->
http://www.youtube.com/watch?v=-UUSoe0N7Cc
Both are Vibrant Performance options. I listed those since after tons of research I decided it was the best sound IMO - hope this helps buddy
Deus has a single black Vibrant muffler on the back. The vid above shows his setup. You can see he modded his bumper to eliminate the drivers side exhaust cut out. PM him and he can answer your questions.
Is also what the fastest NA 6th gen has. Cool if that's what you're into.
My car is a 4 popping POS.
IMO:
For functionality, single 3".
For the look, duals.
Originally Posted by RAZ76
I've seen it on one car and it made the Maxima look like a 4 banging POS. If you like it, do it. I don't, it takes away from the rear I think.
IMO:
This. Single also shaves off some weight so if you're about pure performance then go single. Personally I don't like the look of singles on a 6th gen maybe because I'm used to the dual, or because it would look too much like an Altima, or because I've seen it on Z's and G's and it looks off.
I think people dont like it because your so used to seeing it a certain way. I think my 4th would look terrible with duals but then again I might get used to it after awhile. A dual down to a single just doesnt seem right. If you dont like the look of duals then go single, certainly your choice
I don't remember everything, just ask my wife, but I do remember some random things and this is one of them.
http://forums.maxima.org/6th-generat...installed.html
Nice Vibrants=Winning with the 6ths...
Yeh I reckon fixing the second cut out it will look good and you'll get used to it. I prefer single for a few reasons like better flow. Don't mind the look of it. Less pipes-muffler. Only thing I won't to make shore if I go single setup will this affect performance? Only because it was a double standard. Could it possibly be a gain in performance because it's not going through 2 pipes?
I like single because it flows better. I also like the cleaner look. I never really like 4 pipes sticking out the back but its just my opinion. A single muffler also weighs less, as pointed out earlier and sounds better since you dont have two competing sounds coming out two mufflers. I had a custom mandrel bent 3 inch pipe leading to a Vibrant muffler with two 14 inch magnaflow pre silencers installed on my car.
Check out my threads on this topic:
http://forums.maxima.org/6th-generat...ad-closed.html
One of the selling points for me on my '04 was the twin tip exhaust. I recently put a cat-back system on it, so it now has two 4in tips. I prefer the 4 tip config, so will change later, but the sound of a dual exhaust over single is "heart-rendering". Stick w/ the duals.
